Focus Titanium Mk2.5 Build Diary Has Started...
Yea I noticed that with mine. Each time I looked at it after lowering it changed all the time.
What wind deflectors have you got?
Sent from my C5303 using Ford OC mobile app
Heiko mate wind deflecters.
Yunii
Sent from my GT-I9505 using Ford OC mobile app
  • Replies 979
  • Views 279.7k
  • This is how it was before skirts. Now. Yunii
  • Update ! Project Mountune theme. Yellow stitch leather trim now fabricated & fitted. Yunii   Sent from my SM-G925F using Tapatalk
  • Update! These have arrived. Black Diamond drilled & grooved discs black diamond predator pads Yunii
Car now on ST225 springs
Feels & drives better .notice a difference. Here is before pics.
After to follow once it settles over time.
Yunii
Finally managed to wire up Rca line out converter & it sounds very good. Although will need to tweek with subwoofer settings to get bass & balance right. But its worth it.
Yunii
After fitting ST225 springs this is how it looks. May bed in further i dont know.
Before
& below ia after.
looking good yunii
Looking very good. Car looks spot on with that amount of lowering. Practical and purposeful at the same time. Nicely done :)
Thanks Hassen, its not very low maybe just right for me, could do with little at rear but not by much.bear in mind these are ST225 standard springs not eibachs so only around 30mm drop.
Yunii
Did the springs go on ok from the standard? I'm getting some St wheels and wanna go lower and was thinking about St springs but didn't no whether they fitted alright
Sent from my SM-N9005 using Ford OC mobile app
Yes mate no problem , i suggest once fitted is do 4 wheel alignment / tracking , just so you dont have excessive tyre wear on front
Just bought these for lads fiesta, currently these
Not bad for £169 for alloys,4 centre caps, 16 nuts 4 valves.all brand new. These are 15's alloys.
Yunii
They still have 9-10 sets available.to its a clearance price from national clearance centre ebay.foray motor parts.
Yunii
looks like you got a bit of a bargin there with them wheels for your lads fiesta and they look nice
Not only that their was a tiny little bit of damage in transit so got knocked further £28 off & here is the damage
Note the rip in box.
Here is the alloys on fiesta fitted
Yunii
Yunnii thanks for the info about the St springs fitting the standard focus , I brought a set of front and rear springs today :)
Your welcome mate & glad for you.i suggest go easy on rough roads,potholes,speedbumps as i brole an st170 spring on my mk1.5 2.0 esp few yrs ago.
Yunii
thanks buddy
Focus 5spd illumenated gear knob now fitted .
Please note its wired up to radio loom . Also wired up so i can flip over to different colour.
Yunni when you wired up the gear knob, how do you get it to switch between red and green colours?
What i did was , where the 2 wires red & green come from i put 2 female crimp connecters on each colour wire & used a male crimp connecter on the wire taking feed from radio live. So that you can swap over colours by removing one & connecting other. I hope that makes any sense. See images again & you will see what i mean.
Yunii
  • 3 weeks later...
Update!
Focus level 3 speedo cluster with large info display screen now fitted.
Not cheap but very rare find.
After
Yunii
Update!
After
Yunii
nice mate,
Surely you had to use IDS in order to get this to fully operate rite?
Wasn't just a straight swap was it?
nice mate,
Yes mate straight swap as i have keyless keyfree system & this cluster showed less mileage (26600) to mine 46k so you can add with elm but to lower would've needed ids. Fitted & working in 20 mins .also it from a 1.6 petrol model so was perfect find. I was considering the ST cluster which would work but speed would be out by 5 miles & increasing as your speeding.
I bid on this originally for £230 but was declined 3 times. But my mate Tezza bid & won for £200 .it came with Ecu & remote key so my plan is sell my original cluster with ecu & remote key & recover some or most costs back.
Yunii
looks good
Looks cool :)
