Focus Titanium Mk2.5 Build Diary Has Started...
Actually the sound more crispy & clearer then stock ones. Did the tweeters last week & finished component speakers today. Their is no crackles or ditortion. Although havent tried out with loud sound. Will do on open road so dont distract neighbourhood..pics to follow.
Yunii
If you set the:
Treble +5
Bass to +2
Fader R2
You will get much better output at high levels on the factory headunits.
the speakers you fitted can exceed the volume of headunits amplifier without distortion,
but you will still hear distortion when the headunit is at maximum output Level 30,
This isint the speakers losing response it's the amplifier losing it. Only way to overcome that is with use of aftermarket items but in everyday use level 10-15 is sufficient 👌
I currently have bass +3, mid bass +4 & treble +6.
Yunii
Sent from my SM-G925F using Tapatalk
  • Replies 979
  • Views 279.7k
  • This is how it was before skirts. Now. Yunii
  • Update ! Project Mountune theme. Yellow stitch leather trim now fabricated & fitted. Yunii   Sent from my SM-G925F using Tapatalk
  • Update! These have arrived. Black Diamond drilled & grooved discs black diamond predator pads Yunii
Blimey yuni. Those settings are rather extreme. Have you tried running g the speakers flat? To me if you feel the need to have bass at +3 etc the speakers are not very good.
I left the same settings that i had on stock speakers. Really hadnt fiddle about with it yet.
Yunii
Oh. Then I'd set the tone controls to flat before your new tweeters make your ears bleed.
Rear tweeters bedded in stock tweeter housing.
Yunii
Very clean install. How's the sound so far?
Absolutely awesome. Saying still using sony ford Dab unit
Yunii
I dont know if it wil improve even more as someone mentioned.
Yunii
Forgot to mention , i also run a underseat alpine subwoofer so do get punchy bass on its own .
Yunii
Hi guys , little upgrade & coming thru post soon.
Small vent trim.
Focus RS centre console with black carbon trims inc radio /heater & ash tray door trims.
Probably buy black roof lining & trim also.
Yunii
I admire your dedication mate 👍
There is 2 members that i look upon to for hints , tips & ideas , one is you & other is tezza now owner of mk3 St3. Used to own mk1.5 st170 then mk2.5 st3.
Yunii
liking the new addictions you have bought mate and look forward to seeing pics when fitted
This came this morning
This is only part of it as he did in 2 packages. 1 package Still to come is radio surround/ ashtray door lid/ climate control surround.
Next step once it all arrives to fit.
Then red stitched leather gear gaitor, also would like to wrap armrest in red stitched leather but need foam to give it soft padding.
Then i may do my door cards in red stitched leather.( currently in black leather with black stitch , which were taken off & fitted to my stock ones when leather interior was fitted.
Yunii
Should look really good when fitted, be careful when re-covering the arm rest. It's a very tedious job, it's all plastic welded. I used a hot glue gun when I put mine back together. And spray adhesive on back of the leather. :)
I have plastic welded many times but i am not removing complete but just the top bit .by looking at the rs one it just clips in on top.
Yunii
once them parts are fitted it is going to look good and like the sound of the red stitched leather
once them parts are fitted it is going to look good and like the sound of the red stitched leather.
I deffo will do the gearstick gaitor & armrest cover. But may not bother with doorcards.
Please bear in mind all these pieces need to be glued to existing ones. On the armrest i will use foam for soft padding .
Yunii
Yunii
Yeah,  if I remember right....came off ok,  just getting it all square was the fun bit.
My old build thread
Update!
Fitted RS centre console & Ash tray . Still to fit rs heated seats/screen button housing. 02c9976832bc727f741bbcde7e2845ee.jpg
Also dropped these to carbon dip
Radio surround:
Door open handle surrounds:
This is his quality & similar pattern getting done.
The reason i am having radio surround is cos the one RS one is for climate control & i have manual knobs unit
Yunii
Update!
Fitted the RS heated screens surround .removing the grey carbon titanium one.
Yunii
Now just to wait patiently for bits to come back from custom dip carbon dipping.
Yunii
Looking better there.
Sent from my SM-G930F
