StuartC88 Posted August 8, 2013 Share Posted August 8, 2013 I tried this yestetday. When I went to put the grommet in tho if I put it against the bodywork theres a gap between there and the glass. if I put it against the glass theres a gap between bodywork and grommet. Has anyone got any close up pics of how theres is done? Quote Link to comment Share on other sites More sharing options...
pudrwc Posted August 8, 2013 Share Posted August 8, 2013 I removed my rear wiper on my Fiesta mk6, and once i finished there was a hole where the wiper should have been, you need to get a 'blanking plug' or something like that to block the hole. If this is what your on about anyway lol. Quote Link to comment Share on other sites More sharing options...
AdamC11 Posted August 8, 2013 Share Posted August 8, 2013 Hi StuartC88 Here are some pictures. Its a 24mm outer, tried a 25mm today. Not much better. Im awaiting a plastic grommet at the moment. Please follow link: http://s490.photobucket.com/user/AdamC11_Bling/library/Rear%20Wiper?sort=3&page=1 Cheers Adam Quote Link to comment Share on other sites More sharing options...
StuartC88 Posted August 8, 2013 Author Share Posted August 8, 2013 Hi StuartC88 Here are some pictures. Its a 24mm outer, tried a 25mm today. Not much better. Im awaiting a plastic grommet at the moment. Please follow link: http://s490.photobucket.com/user/AdamC11_Bling/library/Rear%20Wiper?sort=3&page=1 Cheers Adam where did u get it from? Quote Link to comment Share on other sites More sharing options...
StuartC88 Posted August 8, 2013 Author Share Posted August 8, 2013 did u take the rubber bit that was in the hole originally out or leave it in? when I put my rubber grommet over the hole it leaves a gap at the top between the grommet and the bottom of the window Quote Link to comment Share on other sites More sharing options...
AdamC11 Posted August 8, 2013 Share Posted August 8, 2013 I bought the grommets from Halfords. Mine fits flush. I removed the rubber inner where the wiper was. The inner grommet is 19mm and the outer grommet is 24mm. I have poured water over the windscreen and no water has seeped through. Cheers Quote Link to comment Share on other sites More sharing options...
StuartC88 Posted August 8, 2013 Author Share Posted August 8, 2013 I have 2 small gaps. 1 either side of outer grommet ill try post pics Quote Link to comment Share on other sites More sharing options...
StuartC88 Posted August 8, 2013 Author Share Posted August 8, 2013 Quote Link to comment Share on other sites More sharing options...
StuartC88 Posted August 8, 2013 Author Share Posted August 8, 2013 outer is 25mm inner is 19mm Quote Link to comment Share on other sites More sharing options...
AdamC11 Posted August 8, 2013 Share Posted August 8, 2013 Looking good StuartC88, I will change mine to 25mm as im currently waiting for a plastic grommet. Quote Link to comment Share on other sites More sharing options...
StuartC88 Posted August 8, 2013 Author Share Posted August 8, 2013 Looking good StuartC88, I will change mine to 25mm as im currently waiting for a plastic grommet. what about the gaps either side of the grommet in the last pic is that normal? Plus it can be pulled out very easily :\ Quote Link to comment Share on other sites More sharing options...
AdamC11 Posted August 8, 2013 Share Posted August 8, 2013 Thats fine mate. Mine looks the same currently. As long as water doesnt leak in, its fine. Its the risk you take with any rubber gromet, mines been on nearly a week and nobody has touched it. :-) Quote Link to comment Share on other sites More sharing options...
StuartC88 Posted August 8, 2013 Author Share Posted August 8, 2013 Ah thats gd then :). Ill maybe try and find something to seal it with Quote Link to comment Share on other sites More sharing options...
