Interior Colour Matching
Interior colour conversion 12 members have voted
  1. 1. what colour interior panels would best suite a vision blue fiesta
    • gloss white??
      16%
      2
    • vision blue to match exterior
      50%
      6
    • gloss back??
      33%
      4
    • any others???
      0%
      0
Please sign in or register to vote in this poll.
Hi all
Just wondered how to go about painting my interior plastic panels ?? the silvery/grey ones
at the minute i have wrapped them in vinyl but they dont look right look cheap
so has anyone painted them themselves if so what paint do i need and how do i go about doing it???
Cheers
Just got the primer, paint & laquer from Halfords.
Also need a range of different grade sandpaper and smooth down between each coat.
What colour did you go for and paint make???
and how do you apply them ??
one more why do u need to use the sandpaper??
but thank you :)
as the poll above says
just want some opinions on what colour interior panels would best suite a vision blue car
im only spraying the grey/silver panels
IMHO colour coding always looks best.. It's your car though so what ever you like best really lol
I'm going mine all squeeze green once I figure out how to get all the silver bits off.
and sweet and i saw a vid on youtube on how to do it i will link it for you
That's ma vid ;)
Halfords sell spray cans of all the car colours, I used Frozen White as that's what car I had at the time.
You have to sand to give a rough surface for the paint to adhere to otherwise it'll just flake off. You need a lot of patience and time!
ok thank you, do you just rub the paint down after is has dried?? and apply another coat?? how many coats??
and before i put primer on do i sand it down first??
ok i dont have a lot of patience lol time is easy i guess haha
Great vid, whats that yellow tool you use? Just a random bit of plastic or are there actual tools to make the job easier?
Called a trim tool or trim stick. Available on eBay & the likes or some tool shops.
Make sure you get plastic primer, this should be white from halfords, remove the part you intend to spray and sand it to rough the surface a bit (this helps the paint stick better) and then give it a clean with a mixture of water and a drop of fairy liquid. Make sure its fully dried off so that there isnt a drop of water cause it'll ruin any paint applied. Make sure you're in a well ventilated, dust/wind free environment and build up 2-3 light coats of primer leaving 15minutes inbetween each coat. Once the last coat of primer has been applied sit it somewhere where its not going to be disturbed/knocked and leave it to dry thoroughly for 24 hours. This is important to allow it chance to dry properly. Then use a fine grade glass paper wet'n'dry 50/50 from halfords usually works great. Wet the sand paper and very lightly go over the part with the paper just very gently or you'll take the primer off. Again give it a clean with a drop of fairy liquid and water and make sure its 100% dry before proceeding to paint. Again build up 2-3 light coats until the primers fully covered leaving 15mins between coats. Again leave it 24 hours once you've finished painting and put it somewhere safe. Again make sure you wait 24 hours. Then once its fully dry give it 2 coats of clear lacquer again leaving 15 mins between coats.
Just take your time with it and you'll be fine but be prepared to take 2-4 days to do a decent job. Dont rush it or you'll end up regretting it
Gloss white always looks good with blue
Couldn't have said it better myself Dan! Just be really patient and don't spray too much on one coat or it will run.
As for sandpaper I used this: http://www.halfords.com/webapp/wcs/stores/servlet/product_storeId_10001_catalogId_10151_productId_154288_langId_-1_categoryId_255242
600 > primer x 3 > 800 > paint x 3 > 1200 > laquer
Dyou know where I can get Ford Squeeze Green? Halfords website doesn't have any (haven't looked instore yet) and all I can find online are touch up kits :(
Thank you guys :) will order things monday :) big help :)
and try ebay for the colour, if not google it, some companies will mix you a pot if you give them your paint code, i had some done for touch up paint, wasnt paying fords prices
https://www.paints4u.com/AutoColours.aspx?ProductID=6930
put your car details and paint code in and they will make it for you i found squeeze colour on their website didnt look very green but if you have a look im sure u will see it if its the right one
Morning all
i am going to paint my interior parts soon but i wanted to know has anyone painted their front grill mudflaps wing mirror surrounds and rear deffusior themselves? and how did you do it??
or can anyone recommend a good sprayer ?? i carnt find any in my area NR28
thanks
What about blue handles vents steering wheel and white centre console
i have no idea what to do :(
do i leave the interior grey ??
or do i spray myself ?? not paying ridiculous prices
but what colour?? :( vision blue same as outside ?? will it look right?? gloss white ?? i tried vinyl gloss white but looks ok just not as good as painted and dunno white just doesnt look right ?? gloss white and black??
any ideas??? what would also sell easy again??
??? still cannot decide :/
Still cannot decide what colour to have my interior
The grey plastic surrounds do i leave them paint them gloss white or vision blue like the car??
Hmmm :/ what colour does people think would beat suit??
Gloss white
Just dunno :/ im gunna do it but i dunno lol might get both paints and do all centre white then blue vents ???
I've been doing the same thing to my interior, just finishing the CD player surround tonight.
It's easy to remove the plastics, just take your time doing the spraying lol..
