Kpg's Focus Mk2 Titanium
Looks good! Did you buy them from FK? Did you replace the bulbs on the rings?
Yep, I bought these:
http://pages.ebay.com/link/?nav=item.view&alt=web&id=200551050344
This is the link to the headlights I got:
http://www.carparts-tuning.co.uk/Lighting-Tuning/Headlight/Angel-Eye-headlight-Ford-Focus-Yr-05-black-RHD-LHD.html
Sent from my iPhone 5s.
  • Replies 406
  • Views 50.3k
  • Well, car came back from the garage, the alignment on the front is still off a bit so it's going back out on Monday morning. Not to worry. The car was stinkin' filthy so I managed to get a quick wash
  • Edited pic: Sent from my iPhone 5s.
  • The postman brought me a nice wee parcel today. Got my new HID set. Nice and white. Very pleased. I've noticed though that these being 55w, the 'click' I usually get when turning on my light
Thanks for the links! Did you have a good experience with the ebay seller?
No problem. Yea was smooth transaction. They're based in Italy so it takes a couple days longer than usual but other than that, can't fault them.
Brilliant! Thanks for your help. I'll look back through you're thread as I'm interested to see what you've done.
Actually, being the impatient child that I am, I pulled the nose of my car into the garage and installed the lights lol
Peeing with rain and wind blowing a storm I persevered and got them in.
They look class, very pleased:
attachicon.gifImageUploadedByFord OC1421265850.435826.jpgattachicon.gifImageUploadedByFord OC1421265861.570058.jpgattachicon.gifImageUploadedByFord OC1421265874.140368.jpg
The bulbs for the rings were a nightmare. Lots of swearing, my long narrow fingers didn't even help, took a layer of skin off to get the very corner ones changed.
I'll go and get them aligned tomorrow on my lunch.
One thing I noticed was the driver side light was a bit of a tight fit. Lots of fiddling to get right, sits about 1mm further than the passenger side one but only noticeable if you run your hand along the front of the light and wing. Can't see that affecting the beam pattern much but we'll see.
I'll get some daytime pics tomorrow.
Headlights look awsome mate,
Well worth the struggle changing the bulbs too
Not a problem.
Aye I'm impressed so far. Will get them aligned properly tomorrow and see from there.
Do I need to set the headlights at there lowest or highest level before alignment? Probably highest?
Highest mate set the alignment to 0 then align them manually,
This then gives you control to manually dip them lower in 5he event of carrying or towing a load you can manually dip them lower by selecting 0-4 on the alignment wheel.
Thought so. Is there anything I can do with the alignment or should I just get a garage to do it?
Better to let a garage do it.
Using a proper beam setter gets everything spot on.
Yea. I'll get it sorted tomorrow, cheers.
+1 through going to garage for alignment i discoverd one of my bulbs was in upside down aswell,
Spring thing inside the bulb is supposed to be facing the ground
the head lights are looking sweet fella.
liking the st spoiler and alloys
I decided to leave the alignment for now as my MOT is up at the end of Jan and I was going to leave the car in somewhere to get everything checked over anyway.
Main worry points for me would be headlight alignment and the wheel alignment as its moving off to the right a bit. Other than that I'm pretty sure the car will sail through.
The beam pattern at the minute isn't great as passenger side is near facing the ground. Might have a go at evening up the beams as best I can until I get to MOT, save blinding people on the road.
EDIT: Literally just off the phone to a local garage who'll do it tonight after work lol 5min job he said. Sorted.
So I got my headlights aligned and all seems good. Looks like there's more light on the passenger side altogether, I know the lights are naturally angled away from oncoming traffic but just seems there's a bit too much light focused on the passenger side.
Not to worry I suppose, the guy had it on the machine and said all was good so must be ok.
I'm not sure I should chance the new headlights through the MOT. I suppose if I leave the car in for a pre MOT check the guys will sort everything out. Just means I have to change all the LED bulbs back to normal ones which will be a pain to get at those rings again.
If I put the old ones back in they'll need aligned. Then I'll obviously want my new ones back in after the MOT, so because I have to change the motors over each time then the new ones will need aligned again.
Any thoughts? Or am I just thinking too much about it?
You'll be fine with the led bulbs.
Every LED bulb? I have them in the rings of the headlights and the rear license plate. Obviously I can't go in with the HIDs so I'll have to put the normal halogen back in.
Definitely change out the HID but the led's should be no problem at all.
Cheers Clive. Hoping my local MOT testers aren't having a bad day when I go out. Don't want them failing me on LEDs lol
If they're projector lights with HIDs then you might be okay, mine passed an mot without self levelling or washers :)
Better to be safe not sorry though
Yea I was going to say about washers, I'll think I'll just play it safe and put the halogen bulbs back in.
Cars booked in on Friday morning for Pre-MOT checkup. The guy said he'd sort out the rear camber for me too as I didn't get it sorted when the car was lowered. I have the Eibach bolts already so shouldn't be a problem. Hopefully it'll be sorted to a degree were I'll notice the difference but we'll see.
Also, really loving my new HU. Eonon get mixed reviews with their stuff but this is some piece of kit. Looks the business too:
attachicon.gifImageUploadedByFord OC1421676645.202594.jpgattachicon.gifImageUploadedByFord OC1421676655.800577.jpg
Looking very nice. I would be up for this unit now would miss Dab.& voice activated bluetooth thats factoryfitted .
Yunii
Thanks man.
I must get some updated pics up of how the car stands at the minute. It's been freezing cold so haven't had a chane to clean the car inside or out. Once I get a dry day that's mild enough to get washing I'll take some pics. I don't think I've done a 'how it stands today' post yet.
looks a nice head unit you got
