Knocking From Front Offside
Hi mondeo 2.2 2006
A bad knocking from front,getting worse thought it was suspension tops replaced those
Bottom ball joint seems ok
Knocking is immediate on take off forward or reverse
And seems to knock continually on driving,obviously worse on rougher terrain
Is it the drive shaft
Are they easy to change myself
Need help please
Dave
Very difficult to diagnose knocks without hearing them, but if it is worst on rough terrain, i would guess at anti roll bar bushes.
Appreciate it is difficult,but it knocks as soon as you are moving
As soon as the wheels turn
I have had the car up on jacks can't find anything wrong except one shock absorber is covered in oil
Sounds like that is your problem then, happened to my Sons Mk3 but his was the shocker and drive shaft
Got a new shock and spring and changing the bottom ball joint while it is in pieces
So hopefully will cure it
Going to do it sat
do shocks and springs also ya ball joint in pairs
Good fun changing front springs on the Mondeo, without dropping the subframe at one side they are too big to fit out the gap without compressing them slightly
