My Rear Electric Window
Hi all, I'm asking for help, my passenger side rear electric window won't go up its completely down and the other side works as the fuses are for 1 for front and 1 for rear, so it's not the fuse.
The switch on the drivers side control panel works all the other windows but not the rear one, the rear window door switch doesn't work either. Now my car is on the drive with one window down and I can't get it to close.
Any ideas?
Hairy gorilla
All i can think as a starting point is remove the door trim and check that the connector is still in place and that it has not become disconnected. If all plugs in then you need to see if you have got power at the motor.
Just as as thought does the central locking work correctly? in the past i know that some other makes the wires in the rubber between the B post and the door have broken.
Hope this is of some help and sorry if you have already checked this,
