Suggestions For Sub
Already got my amp on 4awg wire from the battery. The fridge sounds cool (no pun intended), wouldn't want to explain if there was beer in it to qa police man! Would be good for camping trips
Fridge would be awsome, or a 12V kettle,
Can legally transport beer aslong as its not in front seats, :)
Ive got an electric blanket to plug in to mine lol pimpin
  • Replies 144
  • Views 12.9k
  • j.beesley
    j.beesley
    I completely abused 2001 - Dr Dre for months when I first got into old hip hop! I'll deifnately take all your comments on board any questions I have I'll drop them your way if you don't mind as you se
  • j.beesley
    j.beesley
    The uv light idea sounds ace I'll be interested to see how it works. I wasn't going to upload the pics until it was fully done but the new led plate I have ordered is going to be here for another wee
  • j.beesley
    j.beesley
    Sorry about the extremely delayed response! I listen to rock/hard rock, metal, hip hop (old stuff!), dance/dubstep and more... I've got my heart set on JL Audio 10W0v3-4 sub and just wanted to know do
If planning to spend at Halfords,
I recommend signing up to premium membership on the forum here to receive a 10% lifetime Halfords discount card,
Use it every time you go, helps alot
10% off all automotive
15% off all bike
IMG_20140731_092921_zpshu50bsv_edit_1406
Thought it was 15% off anything and 10% off bikes? :)
Atleast 10% everytime the college students behind the counter always over estimate it anyways lol
"everyone's a winner baby, that's the truth"
https://youtu.be/tWccMnKyPNw
Whilst I've have you both engaged don't suppose any of you want to explain the effect of ohms on the installation process?
Basically get yourself a multimeter and an audio test tone CD to set the desired Ohm level on your amps to match that of your speakers
See my build thread for "how to" aswell as suppliers here:
Guide to setting Ohms:
http://www.fordownersclub.com/forums/topic/41443-taking-oval-to-blue-horizon-lennys-build-thread-2010-2015/?p=477925
Audio Test Tone CD see link for details of supplier:
http://www.fordownersclub.com/forums/topic/41443-taking-oval-to-blue-horizon-lennys-build-thread-2010-2015/?p=477449
multimeter see link:
http://www.ebay.co.uk/itm/300594820660
Basiclly get yourself a multimeter and an audio test tone cd to set the desired Ohm level on your amps to match that of your speakers
See my build thread for "how to" aswell as supplier links
I recommend doing the above. As stated in the manual for JL Audio amps.
Makes a world of a difference.
Don't suppose you have a link the build thread is a mammoth one!
Must learn to scroll up before writing something...
I edit the post around 20 minutes after posting it; to include the links,
They werent there from the outset to be fare mate.
Content heavy thread!! Took me a while to read through but agree with everything said :')
I was going to do my own sub instillation, got everything out the MK7, trim surround, screws out, complete fascia off and got to the back of the CD.. Took me so long without trim removal tool..
Searched everywhere for the wiring diagram as I wanted to splice/crimp wires to connect the RCA - eventually found it and then realised it was gonna be a pigs ear and didn't want to do anything wrong...
Eventually took it to my local audio specialist and got them to fit it.
Cost me £80 to fit as I supplied all the wires + RCA adapter which was very reasonable. Interestingly and contrary to urban myth you can run power lead, remote and the RCA leads down the same side of the car provided you don't have some monster ICE setup that draws a ton of power so all ran down passenger side under trim/seats nice and tidy!
But I've got a 12" active Edge sub, just to go with the Orange seats ;) ahaha jokes - got it free of a mate that bought an Audi with the bose kit in. That said, even for £100 it packs a lot of bass, had to turn the stereo EQ right down even though the audio place had set it up.
Awesome little piece of kit, would recommend to anyone that wants something effectively 'plug and play' without messing with custom enclosures etc..
It's actually suitable for all sorts, old school hip hop, rap, dub step, house, rock + metal, acoustic, chill out, garage *just to name a few
And don't we all love that 2001 album, have to admit it still gets abused from time to time! :')
Edge subs are good for price - set up sounds good to me! I understand everything. Now apart from 1 thing. The writing configuration on the sub itself to the box port, don't suppose you have a pic/diagram?
The connection between amplifier and sub is just speaker cable,
For optimum bass results i recommend using Vibe 13SPK FlatBass cable,
Its ultra flat meaning easy to fit inside panels or under carpet,
Is primarily my favourite because its got solid copper core strands for optimum transition of voltage.
See link: http://shop.vibeaudio.co.uk/index.php?route=product/product&path=&product_id=105
Sorry I meant the wiring on the actual sub itself and connecting it to the box - I seen its SVC so straight foward to wire. You got any tips for reducing rattles?
Using a 5.5mm drill bit;
Drill pilot hole prior to drilling in the M6 screws.
Some silicone sealant could be used but i didn't bother as the sub enclosure is precision built from laser cut MDF panels.
Can then terminate cables with banana plugs if desired for easy removal of sub enclosure
The top and botton screw hole on the sub are in perfect alignment to each other,
So
Use a straight 90 degree edge such as a saw, to mark the centre of the 10" port to ensure your JL.Audio logo is centre in the end prior to !Removed! it in.
Use the straigt base of the sub enclosure as your straight edge reference :)
Top fella - sorry about the continual questions this is the first 'proper' set up and want it to be spot on
No problem atall mate,
Im always happy to help, im on crutches at present so off work and cant do much else lol
Those gold spade crimp connectors are available from caraudiodirect.co.uk as saw in pictures above.
IMG_20141024_090802_zpsbtj7icx_edit_1414
Get well soon mate! Sub come today after being ordered and posted yesterday lunch time - they also gave me a good discount on the sub top fellas would highly reccomend
http://www.soundevo.co.uk
guess what I found...a bit late but : http://www.midlandscaraudio.com/subwoofers/pre-owned/
A day ago I'd be bashing myself over the head - I'm hugely happy with what I got for the price! Thanks a lot for the digging though mate appreciate it
+1 ive purchased all my JL Audio kit from them
JX400/4 amp, Jx300/1 amp, Two sets of JL C3 650, 10WøV3 sub and JL Audio SGRU-10 10" grill
Saved almost 100 pounds compared to ALL other UK and european stockest's
Lenny from FordOwnersClub recommends www.soundevo.co.uk :)
Don't suppose you have a link to the grill?
Here is a link to the exact item: http://www.soundevo.co.uk/speakers-subwoofers/subwoofers/subwoofer-grills/jl-audio-sgru-10-10-steel-grill-mesh-insert-black.html
IMG_20150124_081950_zpsq3vx6tz6_edit_142
IMG_20150124_082020_zpsrrblxvnq_edit_142
Great for protecting the sub
Ive edit the above post to include a link to the 10" grill
Link: http://www.soundevo.co.uk/speakers-subwoofers/subwoofers/subwoofer-grills/jl-audio-sgru-10-10-steel-grill-mesh-insert-black.html
Also
If you use your boot compartment for grocery shopping; i highly recommend two of these to protect amps from getting scratched in a world of bagless shopping
Link: http://www.ebay.co.uk/itm/161699521427
Out of stock at the minute I'll keep an eye out though thanks. Need an idea of where mount my anp - I'm reluctant to just mount it on the enclosure. Thinking may cut a sheet of MDF to fit over the right wheel arch and carpet it and mount it on that.
Out of stock at the minute I'll keep an eye out though thanks. Need an idea of where mount my amp - I'm reluctant to just mount it on the enclosure. Thinking may cut a sheet of MDF to fit over the right wheel arch and carpet it and mount it on that.
if you were to email them, im sure they wil order one in for you quicker than they would if they were just getting it in to stock the shelves,
Some care or shall we say precautions need to be taken when mounting your amp mate,
It needs to be spaced where it has good air circulation,
And
It cant/shouldn't be mounted upside down,
I had planned to mount my mono amp upside down on the right underside of the boot panel until i read the manual said no upside down because it wont vent off heat in this position,
I was persistent and went back to the drawing board devised a plan to mount it vertical at 45 degrees on some steel custom bent powder coated brackets bolted in to the above panel like this:
I first obtained a welding rod to bend by hand; the required shape:
(A coat hanger will do the same job)
IMG_20150204_180307_zpsfebyzkcz_edit_142
I first experemented with alluminium strips but they dont really bend under pressure,
I then took this template to a local steel merchant whom bent two steel brackets to match its bends.
IMG_20150206_173447_zpsqcq95t8f_edit_142
I then sat the amplifier on to these brackets to mark out some holes for drilling:
IMG_20150206_185356_zpsif6orvru_edit_142
Four 6mm holes up top,
Four 5.5mm holes for the amp (this may differ depending on amplifier model)
I then sent the brackets for sand blasting and powder coating in a black finish to match the amplifiers coating:
IMG_20150312_141507_zps79uhvysb_edit_142
I then went on to eBay and purchased some black anodised Allen head aluminium bolts to mount the amplifier to the brackets,
Securing them at the rear with some M5 stainless steel Nylon lock nuts:
Finished off with some plastic M5 ball head caps:
Mounting like this:
For mounting in to the panel;
Purchased some M6 stainless steel hexagon head bolts:
Followed by some large M6 stainless penny washers to expand the grip surface inside panel:
IMG_20150211_090924_zpsgfvvlfyh_edit_142
Again secured with Stainless M6 Nylon lock nuts and plastic caps:
IMG_20150210_090706_zpsjy2zordt_edit_142
Looks like this:
Ill now create a separate post explaining how to get best ventilation when fitting at 180degrees vertical position,
Its not as sophisticated as the above.
