Reversing Light Switch On 1.8 Petrol Mondeo
I am about to change the reversing light on my 1.8 litre petrol Zetec, but before I do, I need to know the torque wrench settings I should use,
Any ideas?
Solved by V6 Lover
  • Solution
I replaced mine about 6years ago when car had 39k on it,I just nipped it up tight but not forced tight....no problems to date fella,I don't have a torque wrench as I don't really need one,same goes for wheels and never had an issue with them either!!
Now if I needed to put an engine back together after dismantling it then I would use a torque wrench...the Haynes Manuel I have is for the 05-07 mk3 and the section on reverse switch removal + replacement say's
"Unscrew switch from transmission housing"
"Refitting is the reversal of the removel procedure"
no mention of a torque setting so don't worry fella
Thanks for your help. All the advice I've had has been much the same (ie nip it up), so that's what I did. My OCD got the better of me and I took it out, cleaned the area again and refitted it, checked the lights worked (both okay) then ran the engine for ten minutes while I looked for leaks. So far so good.
No problem fella.
