Engine Light Is On. Advice?
Driving to work last night in the silly heat, few minutes from destination and I notice the EML ping up
Have started the car a few times since but it isn't clearing so something is being a mischeif
Could it just be something related to the extreme weather playing up a sensor or could it be something more severe?
I'm shortly gonna hook the car up the the laptop and do a forscan to see if there are any codes but is there any common problems I should look out for?
Car is a 2.2tdci mk4 titanium x sport 78k on clock and on a 58 plate
So I ran a forscan diagnostic and it spat out a lot of dtc codes
Though most of em seem to ping up during tweeking settings with elmconfig. Two codes however are definitely new so I'm assuming are to do with the EML
The list of codes is as follows
===PCM DTC P1102:22-E0===
Code: P1102 - MAF Sensor In Range But Lower Than Expected
Additional Fault Symptom:
- Signal Amplitude Greater Than Maximum
Status:
- Malfunction Indicator Lamp is On for this DTC
- Test not complete
Module: Powertrain Control Module
Freeze Frame :
-GLOBTIM: 1749453 min - Global real time
-TOTDIST: 121039.8 km - Total Distance
-MAINECUV: 14.00 Volt - Main ECU voltage supply
-ESTSERUN: No - Engine status - engine running
-ESTSECRK: No - Engine status - engine in crank
-INCARTMP: 23 °C - In car temperature
-OUTTMP: 11 °C - External Temperature From Sensor
-GLOBTIM: 1750442 min - Global real time
-TOTDIST: 125062.3 km - Total Distance
-MAINECUV: 13.75 Volt - Main ECU voltage supply
-INCARTMP: 24 °C - In car temperature
-OUTTMP: 28 °C - External Temperature From Sensor
===END PCM DTC P1102:22-E0===
===PCM DTC P2562:63-28===
Code: P2562 - Turbocharger Boost Control Position Sensor Circuit
- Circuit/Component Protection Time-Out
Status:
- DTC Maturing - Intermittent at Time of Request
- Malfunction Indicator Lamp is Off for this DTC
Freeze Frame :
-GLOBTIM: 1729727 min - Global real time
-TOTDIST: 124239.8 km - Total Distance
-INCARTMP: 0 °C - In car temperature
-OUTTMP: 27 °C - External Temperature From Sensor
===END PCM DTC P2562:63-28===
===PCM DTC P1750:95-28===
Code: P1750 - Clutch Adaptive Learning Not Done
- Incorrect Assembly
Status:
Freeze Frame :
-GLOBTIM: 1729685 min - Global real time
-TOTDIST: 123719.1 km - Total Distance
-MAINECUV: 12.25 Volt - Main ECU voltage supply
-ESTSECRK: Yes - Engine status - engine in crank
-INCARTMP: 18 °C - In car temperature
-OUTTMP: 13 °C - External Temperature From Sensor
-GLOBTIM: 1729684 min - Global real time
-TOTDIST: 124238.8 km - Total Distance
-MAINECUV: 12.00 Volt - Main ECU voltage supply
-OUTTMP: 20 °C - External Temperature From Sensor
===END PCM DTC P1750:95-28===
Status:
Freeze Frame :
===OBDII DTC P1102-C===
Code: P1102 - MAF sensor voltage indicates a lower air flow than expected.
Status:
- Confirmed - malfunction is confirmed
Module: On Board Diagnostic II
===END OBDII DTC P1102-C===
===SASM DTC None===
Successfull DTC reading, no error codes found
Module: Steering Angle Sensor Module
===END SASM DTC None===
===ABS DTC None===
Module: Anti-Lock Brake / Traction Control Module
===END ABS DTC None===
===HCM DTC None===
Module: Headlamp Control Module
===END HCM DTC None===
===BCMii DTC None===
Module: Body Control Module
===END BCMii DTC None===
===SRM DTC U2101:00-2F===
Code: U2101 - Control Module Configuration Incompatible
Status:
- DTC Present at Time of Request
Module: Speech Recognition Module
Freeze Frame :
-GLOBTIM: 1751117 min - Global real time
-TOTDIST: 125092.3 km - Total Distance
-MAINECUV: 11.75 Volt - Main ECU voltage supply
-INCARTMP: 27 °C - In car temperature
-OUTTMP: 22 °C - External Temperature From Sensor
===END SRM DTC U2101:00-2F===
===PDM DTC B1C15:15-6C===
Code: B1C15 - Righthand Up/Down Mirror Motor Feedback Circuit
- Circuit Short To Battery Or Open
Status:
- Previously Set DTC - Not Present at Time of Request
- Test not complete
Module: Passengers Door Control Unit
Freeze Frame :
-GLOBTIM: 1785712 min - Global real time
-TOTDIST: 121893.2 km - Total Distance
===END PDM DTC B1C15:15-6C===
===PDM DTC B1C16:15-6C===
Code: B1C16 - Righthand Left/Right Mirror Motor Feedback Circuit
Status:
- Test not complete
Freeze Frame :
===END PDM DTC B1C16:15-6C===
===PDM DTC U0208:00-6C===
Code: U0208 - Lost Communication With Seat Control Module A
Status:
- Test not complete
Freeze Frame :
-GLOBTIM: 1729692 min - Global real time
-TOTDIST: 120369.2 km - Total Distance
===END PDM DTC U0208:00-6C===
===DDM DTC B1C13:15-6C===
Code: B1C13 - Lefthand Up/Down Mirror Motor Feedback Circuit
Status:
- Test not complete
Module: Drivers Door Module
Freeze Frame :
-GLOBTIM: 1739434 min - Global real time
-TOTDIST: 124037.8 km - Total Distance
-MAINECUV: 13.25 Volt - Main ECU voltage supply
===END DDM DTC B1C13:15-6C===
===DDM DTC B1C14:15-6C===
Code: B1C14 - Lefthand Left/Right Mirror Motor Feedback Circuit
Status:
- Test not complete
Freeze Frame :
===END DDM DTC B1C14:15-6C===
===DDM DTC U0208:00-6C===
Status:
- Test not complete
Freeze Frame :
-TOTDIST: 120418.6 km - Total Distance
-MAINECUV: 14.25 Volt - Main ECU voltage supply
===END DDM DTC U0208:00-6C===
===RCM DTC U0155:00-08===
Code: U0155 - Lost Communication With Instrument Panel Cluster Control Module
Status:
Module: Restraint Control Module
===END RCM DTC U0155:00-08===
===PAM DTC None===
Module: Parking Aid Module
===END PAM DTC None===
===HVAC DTC None===
Module: Heating Ventilation Air Conditioning
===END HVAC DTC None===
===RFA DTC None===
Module: Remote Function Actuator
===END RFA DTC None===
===ACM DTC None===
Module: Audio Control Module
===END ACM DTC None===
===IPC DTC P1607:87-2A===
Code: P1607 - MIL Output Circuit
- Missing Message
Status:
Module: Instrument Panel Control Module
===END IPC DTC P1607:87-2A===
===IPC DTC U0140:00-2A===
Code: U0140 - Lost Communication With Body Control Module
Status:
===END IPC DTC U0140:00-2A===
===CDP DTC None===
Module: Compact Disc Player
===END CDP DTC None===
The two new ones that stand out are:
Status:
- Test not complete
Freeze Frame :
Status:
Freeze Frame :
Relating to the MAF Sensor and the Turbocharger Boost Control Position Sensor Circuit
Is it possible that the stupidly hot air yesterday could have caused these codes and pinged up the EML?
I have cleared all the codes and the EML magically went out. I will keep an eye on it driving to work tonight and see if it comes back on.
Also, after clearing the codes, a few unrelated codes still remain. Any ideas as to whats causing them?
Status:
Freeze Frame :
-GLOBTIM: 1751126 min - Global real time
-INCARTMP: 25 °C - In car temperature
===PDM DTC U0208:00-2F===
Status:
Freeze Frame :
-GLOBTIM: 1751125 min - Global real time
===END PDM DTC U0208:00-2F===
===DDM DTC U0208:00-2F===
Status:
Freeze Frame :
-TOTDIST: 125143.6 km - Total Distance
===END DDM DTC U0208:00-2F===
Also, I am now having an error message bong up on the convers+ that I can't clear every time I turn on/start the car.
It says tyre monitor malfunction. Though it still seems to be reading the pressures correctly. I'm beginning to think my car really doesnt like hot weather..
