Can You Help?
I've got the dread flashing coil light that kicks in at roughly 2750rpm I've cleaned everything I can and my diag reader tells me that there's no misfire?
Also noticed that the bell shaped sensor connected to the erg valve sounds like it has a loose piece inside I'm not 100% what is it
Mondeo tdci 115 2004
You don't seem to be getting much help. I'd suggest several things to change that
  • give the thread a good title ('Can you help? Flashing coil light.' as an example): you just don't seem to be getting the right people to read it, as it is.
  • mention which engine it is: at least people will need to know whether it is a petrol or a diesel, because the answers will be very different; the year and vehicle model could also be helpful in some cases
  • you probably should specify what you are using to read codes as different readers have different capabilities
  • I can't read the jpeg in your second post; sometimes the site does that, but the point is that it hasn't helped me, at least
What error code are you getting? When was the past fuel filter change?
Po251 I think I'm going to try camshaft sensor as the car it's fine below 2750rpm
P0251 is also a code which can occur when the fuel filter is partially blocked and restricting flow under load.
