Key Fob Loosing Coding
Morning all,
I have just had to re code one of our keyfobs after what i thought was the battery going flat,
However, this morning it has stopped working again, re code it and its fine, anyone heard of this before? or is the keyfob on its way out?
I had that and had to get a new fob, mine is the 3 button type with folding out blade, you only need the button part so no need to get a blade cut also the bit that needs coding to the car via a dealer is in the blade part the bit you code to the car is in the button bit hope that helps
