DI Diesel oil cooler
Well its my first post so here goes.
I have a 2000 plate fiesta with the 1.8 DI engine fitted.Last week it whilst out & about a water pipe burst causing it to get hot.Obviously i stopped when temp rose ,but when i lifted the bonnet & found oil everywhere & oil in the expansion tank.
Once home i set to working through it to find the problem.With the car running ok & no bubbles in water system when full etc soon ruled out head gasket.Further investigation soon uncovered the oil cooler & filter housing all in 1 unit (put 2 & 2 together ) which had obviously split internally.After flushing out the cooling system I then joined the cooler water feeds together & re-routed the water feed totaly bypassing the cooler.Problem solved ,or is it ??.
Not wanting to purchase a new cooler at some £220+ I wandered if anyone has done this before ?? or can see any problems with doing this?? or does anyone know where to get reasonably priced replacement??
Rob
My Boyfriend is a Diesel engineer engine specialist thingy.
I will ask him :) x
  • 3 months later...
Rob
Hi rob i wonder if that problem you had with the oil leak in oil cooler was fixed by bypassing the cooler could you let me know
thanks
leon
