Focus 2009 Mk2.5 Jerking/Kangaroo
beith12
 Share
Hi All, I have a problem with my 2009 Mk2.5 focus (diesel 1.6) where my car jerks or kangaroo's when i lift off the accelerator at certain revs. When i am traveling in 2nd or 3rd gear around 1200rpms and lift off the pedal the car jerks back and forth. I do notice the problem when the engine is at full temperature, but this might not be a factor.
I have replaced the pedal (fly-by-wire) with a part from eBay but made little difference so wondered if anyone on here would know the cause of this?
Thanks in advance
Link to comment
hi andy
get the fault codes checked to see what errors are showing up.
if you have a smart phone then download the torque app and buy a bluetooth obd2 reader off eBay and this will read the codes for you, or you can buy a handheld reader which will do a similar job.
Link to comment
Hi Salsheikh,
Thanks for replying.
I did connect up an obd2 reader and no codes came up (not sure if there is anything specific about fords)
Just driven back home and no problems at all in traffic yet this morning I was getting the issue?!
Link to comment
mmm thats strange that no fault codes came up.
you have a very wierd issue too..you might want to take it to a specialist or ford to have a look at it unless you trust your independent garage to work on it.
to get to the bottom of it could ned up costly as various parts will be changed before a fix is found...unless it has happened to someone else hence why ford might be an option.
Link to comment
see the reader, what kind is it? if you have a wired ELM327 device you should hook up your car to forscan on a computer, then go for a drive and record whats going on, ones to watch would be RPM, fuel pressure, MAP and MAF, DPF temp, DPF pressure and DPF distance until full. might be worth having some accelerator stuff too actual and commanded if there are those options, EGR actual and commanded.
Record it all then see whats what.  at the very least it might help you rule out some stuff which would be my concern with a garage, if its not obvious they might just start fishing randomly replacing stuff until they get lucky.
Link to comment
Thanks James - looked around and some people are say map sensors and some engine mounts so not really sure what to focus on but might try and get the readings that Dee suggested.
Link to comment
i have same issue with my 1.8 tdci mainly steady speed in 2nd and 3rd around 1800rpm to 2200rpm roughly. I used some fuel injector cleaner with a 20 pound fill uo and it eased off to barely minimal, kind of get impression might be dirty injector or one is naff. One thing a remember is without the egr blank its worse.
Link to comment
Thanks ajzetecs, I will go and get some injector cleaner (although I did use a flushing product a few months back) do you think there is chance it could be fuel? I use supermarket stuff mostly.
Link to comment
I only used supermarket fuel for 2 weeks, noticed more smoke and less MPG, it's just not cost effective and look at all the injector problems since they start selling fuel. If you changed fuel filter recently make sure inlet and return are on the right way round.
Link to comment
Never used supermarket fuel should be banned with crap they put in it, i used wynns injector cleaner, av got few suspictions on what might be, dirty injector/faulty, fuel filter or might need to give airfilter clean out
Link to comment
dont agree with the comment. i've used supermarket fuel for ages now without issues. all fuels come from the same place and the more expensive ones have better additives added. cheaper fuel is not poor quality as al fuels have to pass a certain quality standard fit for use.
Link to comment
As above, I've seen Shell, BP, Esso and even supermarket tankers all being filled up from the same pipes for delivery across the country, it's the additives that make one better than the other.
Link to comment
Hi guys, still no further toward finding the issue - not sure it's the fuel as this would be all over the Internet.
I can pretty much pin it down to 1250rpm lifting off (but not completely) in 2nd or 3rd gear and get a jump back and forth.
Saw this post about an earlier model but I'm pretty sure the part has remained the same so now thinking about a new pedal...
Link to comment
Just cause u see the tankers doesn't tell you whats in them, a guy who works delivering fuel told me different buttons for supermarkets at the refinery, sure its only the additives thats what I want to help keep things clean, tiny injectors and all.
Link to comment
  Only 75 emoji are allowed.
 Share
  • Create New...
Forums
News
Membership
