mondeo temp gauge going up and up
EVening all....
It drivers really nice but when drive over 30mph the temp gauge gos up and over 120c then it gos in to limp mode, i stop for 2 mins and temp gos down and its fine.
blowing cold are with heaters too
am i right in thinking its blocked?
If so. is there a drain plug some where so i can flush it?
cheers
Sounds like the coolant isn't circulating which could be an air lock but most likely no pressure in the system.
Try changing the expansion tank cap first before you spend anything significant on it. What year is the car and how many miles on the clock?
