Dale
Hi just purchased my Mondeo 1.8 tdci edge,never had a car with turbo and I can hear quite a loud wereing noise when the turbo kicks in are they normally noisy?I see people look when I go past sorry if I'm sounding thick but don't know if it's on its way out or not,Any help would be appreciated thanks.
Could be a split intercooler hose.
Cheers I'll get my mate to take a look
I've got the same engine on a MK2 Focus & the short black 90 degree pipe to the left of the EGR valve has a habit of fracturing.  I replacement mine with a silicone hose & 3 years on it's still going strong.
If you get someone to rev the engine to about 2500 rpm to spool up the turbo, have a listen in the engine bay & use your fingers to run around the undersides of the pipes.  Even if the split is tiny you'll feel a bit of air being blown onto your hand/fingers (assuming the issue is a split hose).
Turbo's on the 1.8 TDCI don't have a reputation for blowing up, although like any turbo a decent supply of reasonably clean oil is vital to maximising it's lifespan.  So if the last owner has only done an oil change every 3 years, that won't have done the turbo any good.
