pjbude Posted March 7, 2016 Share Posted March 7, 2016 Hello. Installed a stainless steel blanking plate to the egr valve on my 2006 focus 1.8tdci. Duratorq. Now a light keeps coming on in the rev counter. Its a cog with an asterisk inside it. Also the egr valve seems to have gone very loud. No engine management light. Is this normal? Cheers Quote Link to comment Share on other sites More sharing options...
ippy Posted March 7, 2016 Share Posted March 7, 2016 If you have got an electric egr I think you may have to plug it into a computer to have it deleted im not 100% sure, mine is diesel, it might pay to take it out and see weather you still get the lite, also have you put it in the right side? Quote Link to comment Share on other sites More sharing options...
TomsFocus Posted March 7, 2016 Share Posted March 7, 2016 Did you keep the gasket the right side? The noise will be a boost leak if not. Does the little cog not show up a message on the Mk2? On the mk2.5 it does. 1 Quote Link to comment Share on other sites More sharing options...
FatHead1979 Posted March 7, 2016 Share Posted March 7, 2016 3 hours ago, pjbude said: Hello. Installed a stainless steel blanking plate to the egr valve on my 2006 focus 1.8tdci. Duratorq. Now a light keeps coming on in the rev counter. Its a cog with an asterisk inside it. Also the egr valve seems to have gone very loud. No engine management light. Is this normal? Cheers It's unusual for an EGR blanking plate (if fitted correctly) to trigger a warning light on the Lynx engine. I did mine approx 2 years ago & no noisy EGR valve or warning lights. I'd check for boost leaks 1st mate. 3 Quote Link to comment Share on other sites More sharing options...
pjbude Posted March 9, 2016 Author Share Posted March 9, 2016 On 22/02/2016 at 5:04 PM, pjbude said: Hello. It came with two new gaskets so fitted one either side of the blanking plate. Fitted it to the top pipe. Warning light doesn't throw up any codes. Tried taking it out and no more warning light. EGR still sounds quite loud though. Quote Link to comment Share on other sites More sharing options...
pjbude Posted March 18, 2016 Author Share Posted March 18, 2016 On 07/03/2016 at 10:29 PM, 1979Damian said: It's unusual for an EGR blanking plate (if fitted correctly) to trigger a warning light on the Lynx engine. I did mine approx 2 years ago & no noisy EGR valve or warning lights. I'd check for boost leaks 1st mate. hello. How would I check for boost leaks or where should I look? Quote Link to comment Share on other sites More sharing options...
