Someone has an answer to this?
have a friend driving a GALAXY 2008. Has bought an aftermarket radio to replace the original.
Has problems with the control on the steering wheel.. The canbus module for the steering wheel is probably permanently activated and draws its battery low/empty.
But he has recently discovered that the attached module is intended for the Mondeo.
Have also already learned that a canbus module is up to 30 min "active" after closing the car.and then goes "off"
This one , apparently, does not.
Does anyone ,by chance,  know if there is a difference between the module for a "convers +" and a regular LCD?
I really can not think of anything else,  other than that this module is either broken, or quite simply unsuitable for the Galaxy ...
Someone another idea?
  • 1 month later...
they do use different versions as far as I know as the resistance measurements differ massively, which is why it wont be shutting down.
