Mondeo turns over but won't fire
Hi guys I need some help with a problem with my mondeo. On Saturday evening my car started but with in seconds stopped, tried to start the car again but it turns over but will not fire.
I borrowed a code reader but it shows no codes don't think it's the right reader for my car). Have however got a couple of codes from test mode
One is F00616 and the other is C41668
I think fuel isn't getting to the injectors so could it be the fuel filter (which needs changing anyway)
I appreciate any help/advice you can give me
Cheers
Brian
  • 4 weeks later...
start with the fuel filter and make sure you definitely fill and prime it correctly.
You should get a modified ELM cable and download FORSCAN for the best diagnostics you can do at home.
