Mk2 focus facelift Front disk replacement
Russ
 Share
Hope this is in the correct section, apologies if not.
I'm replacing my front disks/pads this weekend on my 2008 mk2 facelift focus. I've read some horror stories on other forums about stuck disks and just wondered has anyone here had any problems replacing theirs?
Fitting Brembo disks and pads, got a 7mm Allen key ready. I've changed disks before on a fiesta mk6 and a cavalier TD, just haven't done any on a focus till now. Thanks.
Link to comment
9 minutes ago, TomsFocus said:
Did my Focus ones last year, probably original given the age and mileage, didn't have any problems at all.  :smile:
Mine are original and have only done about 44,000 Tom but the disk has a slight lip on it so wanting them done before my MOT in September rather than have the garage attempt to rip me off with the usual patter of "hmmmm your pads/disks are 80% worn, we can do them for £***"" using the cheapest of parts!
Link to comment
I did fancy painting them while I had the wheels off. I also almost bought the pagid disks/pads but plummed for the Brembo at £1 a disk more! (I like the fact your disks look coated, normally any I've bought are just finish turned with no coating)
I actually emptied my 'basket' on the website I got them from then later received an email offering me 20% off.
Link to comment
Pagid discs are always painted, looks cool until you use them lol...  But seriously I find it stops the central hub and outer edges rusting as quickly.
I've managed to warp a few Eicher discs so always used Pagid pads & discs ever since, not used Brembo's that I can remember though so can't comment on those.
  • Like 2
Link to comment
Up till now I've always used either Brembo or Ferodo and haven't had any problems but I've seen some cheap brand disks that weren't even equal thickness on either side of the vented centre!
  • Like 1
Link to comment
Well, disks are on, old ones were rusted onto the hub but tapped off with a plastic headed mallet, Pistons eased back ok. All in all took me about 75 minutes with help from my daughter to check the brake fluid didn't overflow. Copper grease onto the mating faces of the disk/hub/wheel, jobs a good un. Now let's see how achy I am in the morning!
  • Like 1
Link to comment
19 minutes ago, Russ said:
Well, disks are on, old ones were rusted onto the hub but tapped off with a plastick headed mallet, Pistons eased back ok. All in all took me about 75 minutes with help from my daughter to check the brake fluid didn't overflow. Copper grease onto the mating faces of the disk/hub/wheel, jobs a good un. Now let's see how achy I am in the morning!
Lets see the result then :). I have just purchased some brembo's for mine too for the braking performance and the look of drilled discs :tongue:
Link to comment
I was going to take photos but didn't remember until the first wheel was back on but I'll take a photo of the old disks tomorrow to show how bad they were, and only 44,000 miles on an 08 plate!
Link to comment
Don't forget to show us the new braking setup as well so we can compare. 44K for your FIRST brake change on the car?
Link to comment
44,0000 miles and it's the first brake change (genuine Ford),  the car is 8 years old. Unfortunately I'm not taking the front wheels off as its starting to rain here but here are two pictures of the rear of old disks. The fronts look quite good but the inside faces on one are terrible. Pads were down to about 4-5mm, hence changed them. The new disks and pads are Brembo
Link to comment
  • 3 weeks later...
Just now, TomsFocus said:
You need some tyre black now...nothing worse than black rims and grey tyres lol! :biggrin:
I actually have some Mequiars tyre gel that I will be applying later. Should be sweet
Link to comment
  Only 75 emoji are allowed.
 Share
  • Create New...
Forums
News
Membership
