Confused! Mk 1.5 wiring on Gem for aftermarket locking kit.
Mattypompy
 Share
Hi guys,
Can any of you electrically savvy folks help me on identifying the correct wiring for installing an aftermarket remote CL kit?
My original one failed when I changed the battery in the fob and the car refused to go into programming mode. I have the Haynes wiring diagram of the GEM and have already connected the power to it. Now I need to identify the correct wires for the two, lock/unlock, from the kit to attach to. I have deduced, hopefully correctly, that I need to connect the lock wire to blk/grn and unlock to blk/org that controls the drivers door motor assembly. I have unplugged all GEM multiplugs that are colour coded. They are, starting up from the floor vertically; blk/grn/blue/wht/purple. Thing is two plugs have said blk/grn and blk/org wires. The white one and the purple one. The white one has two black /org ones.
Can anyone advise which plug I go for?
I have looked at the how to guide but the wiring colours are different. This is a negative trigger system I'm assuming?
I have referred to
http://www.justanswer.co.uk/ford/7s6qi-need-help-wire-remote-central-locking-car.html
but am none the wiser!
Cheers.
51 plateplate tdci
Link to comment
Here are two Haynes wiring diagrams. One with the GEM ,on the rhs, and the drivers door motor assembly, the other with the door switche wiring. My issues is to identify these on the GEM multiplug. Also a pic of said plugs. A full GEM wiring diagram would be great!!
Cheers guyts.
Link to comment
Cheers guyts.
Sorted with help from Dan and his wiring expertise, cheers!!
Link to comment
  Only 75 emoji are allowed.
 Share
  • Create New...
Forums
News
Membership
