TopCat Posted August 14, 2016 Share Posted August 14, 2016 Can anyone help? I have a focus 2006 2.0 auto and have been hearing what appears to be coming from the front passenger side wheel area, a clicking noise almost like what we use to put on our bike wheel, can't see anything obvious and It gets louder after long journeys. I thought it may be the bearing so changed the hub. No such luck! I am now at a loss - hoping not new gearbox time! Quote Link to comment Share on other sites More sharing options...
Russ Posted August 14, 2016 Share Posted August 14, 2016 Have you tried lifting that corner of the car up, removing the wheel and rotating the hub to see if you can hear anything? Quote Link to comment Share on other sites More sharing options...
TopCat Posted August 14, 2016 Author Share Posted August 14, 2016 Yes, I even had it in axle stands, in gear and wheels turning - it is hard to hear at times. I thought it was the bearing - a mission later I took it for a test drive but still the same! Quote Link to comment Share on other sites More sharing options...
ajzetecs Posted August 14, 2016 Share Posted August 14, 2016 i have same issue sounds likes sumit stuck in tyre but nothing present, mainly when turning, it happened a while back and removed corrosion around brake disc and when away but back again worse Quote Link to comment Share on other sites More sharing options...
pky Posted August 14, 2016 Share Posted August 14, 2016 I once couldnt have quite seated the brake pad retaining wire clippymebob after a Pad change and intermittently it'd click click click, then be fine then start again. I thought about it then replaced them and that sorted it. Long shot maybe! 1 Quote Link to comment Share on other sites More sharing options...
TopCat Posted August 14, 2016 Author Share Posted August 14, 2016 Thanks people. Mine seems to get worse after long journeys and it / I can only hear it on de-acceleration. Quote Link to comment Share on other sites More sharing options...
