Radio Won't Turn After Dead Battery
You still not changed that radio yet?? :tongue:
Have a read of this excerpt from the Ford workshop manual-
Basically the Dealership should be able to do a DTC scan and pinpoint if it's an actual module failure or simply a communication failure between the modules themselves.
 I've change the  Radio  still the same ***** off now
  • 5 weeks later...
sure halfords do retro fit kits for your model . bin it and just put a standard din fit radio in and take ford out of the problem .
  • 2 years later...
On 11/23/2016 at 9:36 AM, TomsFocus said:
In 2 years of no use it could've got damp inside and broken tbh.  Bit of a long shot but do you know anyone else with a Mk7 Fiesta that could borrow their radio to test?
Also have you definitely pressed the on button?  It's the volume knob on them iirc.
I just came on with the same problem after getting a new battery. Turns out I didn't realise there was an on button! Thanks so much for pointing out the obvious 🙂🙂 🙂
  • 8 months later...
My car is doing exactly the same as this. I picked it up from the dealers, where it had sat with a flat battery for an unknown amount of time. Did you ever get to the root of the issue?
My dads focus had problem with radio , we warmed it up with hairdryer and it turned on was just something i saw on online forums , but think radio had fault , hes not got the car now though.
