Any tips for De-icing?!?!
My trusty 12 year old will finally be driven every day from boxing day, however since the cold weather has started the locks freeze and the windows freeze, inside and outside!!!
i timed myself doing it this morning and it took 20 mins, not time i have in the morning!
i appreciate that with frequent use the inside probably won't freeze but the locks still will! any tips on how to stop this??
Try 3 in 1 oil in the locks, but not wd40. it always worked on my older fords
Get a cover for the windscreen to cut some time off.
You get sprays at Halfrauds which you spray on the night before which are supposed to stop freezing (Never tried them myself). Something I have tried is spraying a mix of vinegar and water at about 1:4 on the windows the night before, this stops freezing but makes a bit of a mess as it drys in and you get brown streaks :lol:
You could always try tapid water aswell, although probabably better leaving this for when youre in a massive rush. Don't no about the locks, sorry :lol:
You can also get lock de-icer in a little bottle with a nozzle on - try Halfords or similar
But by far the best prevention is a complete car cover (again, try Halfords or other online car parts dealers) - this will definitely keep frost at bay and will help to minimise any ice developing :)
cheers guys :)
I use two old blankets for me wifes car...job done!! LOL!
Yeah, bit of oil in locks...as said not WD40 as its 90% water.
Also, bottle of water, about 20% hot and 80% cold water should do it...go easy with the hot, could crack glass....but hot water wouldnt hurt a lock...done that before...or a hot air gun!!!
People using kettles to defrost are just asking for it!! :lol:
No it aint! :P
I think someone already was referring to this but my dad used to have a little mini can of de-icer that had one of the little straw like things that you get with WD-40 which you can spray directly into the locks, not sure you can get it anymore but that worked really well.
"No it aint!"
yea, it is!...it used to be 90%....fair play, i think the ratio is now down to about 70%...still a lot!
The guy above got right idea...think you can still get that :)
What about those hot key things you can get?
i'm just going to go with keeping a door unlocked!
"No it aint!"
again: no it aint!
WD-40 is a water displacer (Probably what the 'WD' stands for :rolleyes: ). As such it does not contain water!
However a good alternative to WD-40 is something called GT85 which in most ways is far superior, though its about twice the price.
wd40 is mainly water...sorry...fact! check the ingredients!
again: no it aint!
Give it up dude, you're wrong. ;)
According to the ingredients on my can - it's 60-80% petroleum disstilate, so I don't see how it can be 70% water.
Oh, and Wiki confirms this - as well as everything Jonny has said about it...
WD on Wiki
Think you have to admit error here Piggy...
STOP ARGUING IN MY GOD DAMN THREAD!
Calm down princess - don't make me hit the edit button... :lol:
WD on Wiki
I sure he didn't mean it but i think that this is what is know these days as an 'Epic Fail' for Piggy.
too right!!!!
I am happy to admit when I am wrong, seriously, just done me own research, thought this lot be useful below, explains the name too....
It is little embarrassing buts its like me being told a spanner isnt a spanner...when i went into the trade that was one of the first things I was told, being a DIY mechanic with me dad i swore by WD40, and got 'got put straight' in the garage I worked at for years that WD40 was mainly water?!?! I have said it for years?!?!/ What a prune...I am having words with me old work pal!!!
Oh, rub it in and I take meself off to spending my time on another forum :ph34r:
heres the info I got....
What does WD-40 stand for?
WD-40 literally stands for Water Displacement, 40th attempt. That's the name straight out of the lab book used by the chemist who developed WD-40 back in 1953. The chemist, Norm Larsen, was attempting to concoct a formula to prevent corrosion-a task which is done by displacing water. Norm's persistence paid off when he perfected the formula on his 40th try. Please see Our History for more information.
Top
What does WD-40 contain?
While the ingredients in WD-40 are secret, we can tell you what WD-40 does NOT contain. WD-40 does not contain silicone, kerosene, water, wax, graphite, chlorofluorocarbons (CFCs), or any known cancer-causing agents.
Top
What is the shelf life of WD-40?
Indefinite. While some products may have an expiration date, WD-40 lasts so long that a "use by" date isn't necessary.
Top
How long does WD-40 last after application?
While this may vary depending on the application, WD-40 remains effective even after it appears to dry. The corrosion and rust protection ingredients remain adhered to the surface. External conditions may, of course, require additional applications of WD-40 for maximum protection.
Top
I've heard that people use WD-40 as a cleaner/remover. What can it be used on?
WD-40 removes sap, tar, adhesives, labels and tape from surfaces without damaging existing paint. It's an effective cleaner for tools, equipment, and vehicles. Use it to remove splattered bugs from the front of cars. WD-40 will even help remove gum from carpet. Just spray, wait, and wipe with a clean cloth.
Top
How is WD-40 different from 3-IN-ONE®?
WD-40 is the ultimate multi-purpose problem solver. WD-40 cleans/degreases, penetrates to loosen up stuck parts, prevents corrosion and is a light lubricant. 3-IN-ONE, with it's special drip spout, enables you to lubricate without any overspray or splatter. 3-IN-ONE is ideal to use on tools, rollers, hinges, in-line skates, wheels...nearly everything that moves.
Top
What does WD-40 do?
WD-40 fulfills five basic functions:
1. CLEANS: WD-40 gets under dirt, grime and grease to clean. It also dissolves adhesives, allowing easy removal of labels, tape and excess bonding material.
2. DISPLACES MOISTURE: Because WD-40 displaces moisture, it quickly dries out electrical systems to eliminate moisture-induced short circuits.
3. PENETRATES: WD-40 loosens rust-to-metal bonds and frees stuck, frozen or rusted metal parts.
4. LUBRICATES: WD-40's lubricating ingredients are widely dispersed and tenaciously held to all moving parts.
5. PROTECTS: WD-40 protects metal surfaces with corrosion-resistant ingredients to shield against moisture and other corrosive elements.
Top
What surfaces or materials are OK to use WD-40 on?
WD-40 can be used on just about everything. It is safe for metal, rubber, wood and plastic. WD-40 can be applied to painted metal surfaces without harming the paint. Polycarbonate and clear polystyrene plastic are among the few surfaces on which to avoid using a petroleum-based product like WD-40.
Top
What about using WD-40 on my sports equipment?
WD-40 is safe and effective to use on all types of sporting goods. Use WD-40 on your bike to clean, degrease and lubricate your chain, derailleur, gears, cogs, and moving parts. It will help remove stickers. Use WD-40 to clean and protect your gun. It will prevent corrosion and it won't damage bluing. Spray it on dirt bikes to protect parts and prevent mud from sticking. Use it on watercraft to protect metal surfaces from corrosion and to drive out moisture. WD-40 is also great for cleaning golf clubs and preventing rust on hockey skate blades.
Top
What is the propellant in WD-40?
A propellant is the stuff that helps pump WD-40 out of the can. The propellant used in WD-40 is carbon dioxide (CO2). CO2 is an inert gas which helps empty the can. Plus, the addition of CO2 reduced the number of VOCs, which helps preserve the environment. Be sure to point the spray nozzle toward the dot on the top of the can to ensure that the can fully empties.
Well I'm glad you believed me in the end! Although I find it a bit odd (and quite hard to understand!) that you believed somebody who told you that the main ingredient in a water displacer was water!! I do sympathise though, it is a bit out of order that your so called pal actually left you believe it for all those years after pulling your leg... :(
Maybe you should think up something similarly odd to get back with lol? like antifreeze is made out of cat pee or something like that...
wasnt a leg pull, i know when he would be doing that....be surprised though what some ingredients are in some fluids used in the motor trade...or horrified!!
And I believe the info I found...not you :P he he :lol:
lol, the only bit you needed to know I already told you hours ago! :P
