My mk 2.5 Titanium
Bonnet lock isn't hard to remove just ease tue 2 platis clips apart n it pulls out. Will make sence once u r looking ar it. make sure you dont allow it to drop down once youve freed it from the upper grill as the weight can pull it n disconnect it from the bodwen cable.
  • Replies 230
  • Views 26.7k
  • Commencal24
    Commencal24
    ST/Zetec S spoiler was fitted yesterday and really sets the car off much better than the standard one. Only one stupid comment from the numpty across the road too 😩
  • Commencal24
    Commencal24
    Lee on here has one fitted.
  • Sorry for the delay. Blame the typical Sheffield weather!!
Ok, sounds pretty straight forward, I finish work for a whole week Friday so plan on doing it then
Ive done it twice as went to a zetec s grill then the 1 i currently got.. its straight forward n simple. The bonnet lock is basically held in by 2 big plastic lugs n u just pry em apart wi a flat head screw driver n pull gently back n it pops out. Just make sure not to let it then drop down on its own as i did n it disconnected the bowden cable from the act lock mechanism...
Whats the radio receiption like with the stubby aerial?
I don't know as I usually listen to music through my phone, I'll have a try on the way home tonight and let you know.
Wow just had a message saying my grills have been delivered!! Amazing service seeing as I didn't order them till this time yesterday
Fitted pedal covers tonight.
Decided against paying the price for Ford ones.
ignore the state of the carpets 😉
If anyone else or thinking about getting these id recommend, painting the metal tabs on the accelerator first.
Grills fitted today, I was a little apprehensive about the upper with what can happen with the lock but it was simple tbh, the fog surround were an absolute nightmare though as the clips just didn't want to fit in the slots!
Also fitted nightbreakers to the fog lights too, which on the focus bulb list were H8 but were actually H11's
Looks great honey combe front really improves the look. Gloss black or colour coded bonnet lip will make the front end even better
Something like that is on my ever growing list of things to do.
A splitter or I've seen a sea grey ZS spoiler for sale are next
Do you mean rear spoiler?
Had mine sprayed gloss black along with mirror caps
Yeah spotted one on eBay, just need the funds 😢
Looks so much better than the standard spoiler
Totally agree with you 👍🏼
This came through the post yesterday
cost £80 + £15 postage has a light scratch right on top and a small scratch down to primer on the outside edge, but apart from that it's in excellent condition.
Had loads of tape residue on it when it arrived as apparently the previous guy had smashed his rear window and so taped a plastic sheet from the spoiler 🙈 But sticky stuff remover easily got rid of it.
Also fitted colour coded mist washer jets over the weekend. Not  got round to pics just yet, I did drop one of the plastic clips holding the sound proofing on the bonnet which ended up with me taking the tray off from under the car.
Looks good have you got the clear brake light if so it's the idea time to tint it
No it came with the red one, but it was exactly what I was thinking, I was hoping eBay might have a cheap one going but no luck.
Try to ask Brakers that have st's they are scrapping you may also need the connecting loom from the tailgate gate as it's different I seam to recall but could be wrong
It's came with this loom, is this not the correct one?
I assume that's an ST spoiler for a mk2 & mk2.5 focus?
The st has a different loom connector,
If you had purchased it brand new from ford;
http://www.fordpartsuk.com/shop/ford_focus_st_rear_spoiler_2008_f_1689072.htm
it wouldn't have a loom connector atall it comes with crimps instead,
But both on the high level brake light look are black 😅
so you need to turn on the ignition and press the brake pedal using either;
A: the missus
or
B: the head and handle of the vacuum cleaner jammed between pedal and seat to act as a foot activating the brake lights
while you wire in the new loom using crimps and pvc tape.
also before fitting purchase some bathroom silicone and apply a ring of it around each bolt hole between the outside boot and the spoiler.
this prevents the common boot leak problem from ever happening to you Hi5🙋
A: the missus
or
Thanks for that Lenny, stupid me assumed it would just be a case of putting the connections together, I guess nothing's ever simple 😂
The only connector left on it is; the loom plug in to the led brake light unit.
Also put a blanket on the roof to protect from scratching when fitting.
Good thinking 👍🏼 I'll undoubtedly get some stupid comments from the guy across the road as I'll be as he calls "tinkering with my car" 🙄
Heres my colour coded washer jets.
Awesome job by chris at paintmodz
Say nothing; take off the old spoiler, calmly walk across the road and beat him repeatedly then walk away three steps before returning to give em a kick.😁
