fiesta mk5 heater wasnt working
right guys hope somebody can help,the wife has a fiesta and the heater wasnt working,
on its last service the fitter said the heater matrix was blocked with rust/crap as there has been no antifreeze in the car.
so i removed the old heater control valve and flushed the matrix out both ways till the water ran clear alot of crap/rust came out
also flushed the whole cooling system out and cleaned the header tank bottle,
i then refilled the sytem and added antifreeze and fitted a new heater control valve from ford,
still rubbish
so when the car is running if i put the heater control onto hot and leave it switched off the pipes leading to the heater control valve get hot and also the other pipes past the heater control valve leading to the matrix get hot
as soon as i put the heater on to blow in the car the heating in the car is warm at first then goes coldddddddddddddddddddddddd
any ideas?????
thanks paul
got air in there somewhere...very typical symptoms of air in there! :)
so whats the best way of getting the air out ,ivesqueezed all the pipes and ran it till the thermostat opened up and topped the header tank back up,am i missing something
thanks paul
there should be some bleed valves on the system...look like either a screw head or a tyre valve dust cap...
remove, start engine, prepare to put back on once waterfountain begins!!! :lol:
not seen any m8 are u sure
got to be something...maybe someone online soon with a mk4/5 with the heater valve will confirm or not so for us/you/me!!!
sounds very much like air lock...when I did me mums punto matrix, was ok after I bleed it...lots of blead points...but not quite right, took me 1/2hr of water/A/F and getting engine revvs up then down, using different bleed points to force air to top!!
check the radiator too, often bleed point on one end :)
so guys are there any bleed points on a mk5 as i cannot see any,other than that whats the best way of bleeding the system of air????
cheers paul
