Help! Sump plug / in the middle of oil filter change
Good job.  Where did you get the new longer bolt - is it a normal bolt or a "special" sump plug bolt?
  • Replies 51
  • Views 24.6k
  • stop fussing and either use repair kit or new sump, soon be time for another oil change by the time the decision is made!! lol
  • 34nm
  • That's the whole idea. If it was a damaged sump plug you'd simply just replace it.  If you go down the route of using one of those kits, I'd recommend some cutting compound of sorts on the tap -
Normal hex bolt bought from screwfix in a pack of 10.  Cost me £3.59.  Here's the link http://www.screwfix.com/p/set-screws-a2-stainless-steel-m10-x-25mm-10-pack/53083
