Fuses
Might be a stupid question but yesterday before I took the car to the garage to get the windscreen washer problem fixed, me and my day decided to look through the cars manual and check up if it was a fuse that had blown. Problem 1, there were two fuse boxes, one in the engine and the other in the glove box which i might add isnt the easiest to access to. Anyway my dad has a ford van and in his booklet theres a diagram showing what fuses are what, the fiesta booklet doesnt have any diagram at all it only states which fuses are in the engine and which fuses are in the glovebox fuse box. Anybody know if there is actually a diagram anywhere?
Cheers
Hi. I have just replaced mine and there is a diagram on the glove box when you finally manage to pull it out. My M7 manual does not have the diagram but does have a table showing the number which corresponds to the diagram under the glovebox, (but there's also a washer picture). Mine was third from the left near the bottom if I recall correctly.
Hope this helps. Seems to be a real problem this winter!
Cheers
Just replaced mine 10 amp mini blade red it was behind the glove box the end fuse lookin left to right hope this helps it does say in the manual think it say no7 fuse which if u count i think its 7th fuse from left.
