Legacy7770 Posted October 1, 2017 Share Posted October 1, 2017 Hello everyone. Just got hold of a 2013 focus 1.0 ecoboost with suspected head gasket fault any know the correct cylinder compression figure?? Thanks Steve Quote Link to comment Share on other sites More sharing options...
stef123 Posted October 1, 2017 Share Posted October 1, 2017 Iantt will know what the figures should be. by any chance has it suffered a burst degas hose? Quote Link to comment Share on other sites More sharing options...
JW1982 Posted October 1, 2017 Share Posted October 1, 2017 Ford does not specify the exact compression figures for this type of engine. Presumably because different brands/types of compression test gauges often give different figures. The Ford Etis workshop manual litterally says: " Carry out the measurement in accordance with the instructions supplied with the measuring device on every cylinder using a suitable compression pressure recorder with a suitable adapter. If all measurements appear equal across all cylinders, no fault can be suspected". 1 Quote Link to comment Share on other sites More sharing options...
iantt Posted October 1, 2017 Share Posted October 1, 2017 engine will be scrap 1 Quote Link to comment Share on other sites More sharing options...
Legacy7770 Posted October 1, 2017 Author Share Posted October 1, 2017 Thanks for the quick replys guy's. I'm quite new to the 1.0 ecoboost engine. I'm pretty sure it's going to be toast but I want to know why.!! Can someone let me know where the degas hose is. Ounce again thanks Steve Quote Link to comment Share on other sites More sharing options...
iantt Posted October 1, 2017 Share Posted October 1, 2017 the hose bursts near to the turbo where the smaller pipe tees off 1 Quote Link to comment Share on other sites More sharing options...
iantt Posted October 1, 2017 Share Posted October 1, 2017 the one i have shown is the later modified version Quote Link to comment Share on other sites More sharing options...
Legacy7770 Posted October 2, 2017 Author Share Posted October 2, 2017 Thanks mate you're a star much appreciated Quote Link to comment Share on other sites More sharing options...
Legacy7770 Posted October 2, 2017 Author Share Posted October 2, 2017 Thanks mate just found the degas pipe has split in the same place as the photo. Removed plugs and water in the cylinders going to do a compresion test just to find out what's going on?? Yours sincerely Steve Evans Quote Link to comment Share on other sites More sharing options...
stef123 Posted October 2, 2017 Share Posted October 2, 2017 The time would be better put towards loosening the mounting bolts for the engine lol. 2 1 Quote Link to comment Share on other sites More sharing options...
iantt Posted October 2, 2017 Share Posted October 2, 2017 Contact ford garage. They may help. Quote Link to comment Share on other sites More sharing options...
Legacy7770 Posted October 2, 2017 Author Share Posted October 2, 2017 Hi guys quick update so far. Car turns over fine but won't fire water in all cylinders. Ok head gasket I think next compression test all cylinders have 180psi !!! So now I'm thinking it's not a compression problem but how is the water getting into the cylinders? thanks for all the help so far guys steve Quote Link to comment Share on other sites More sharing options...
iantt Posted October 2, 2017 Share Posted October 2, 2017 engine cooked, head warped, game over. 1 Quote Link to comment Share on other sites More sharing options...
Legacy7770 Posted October 2, 2017 Author Share Posted October 2, 2017 Thanks for the quick reply. can I get away with swapping the head?? Can't understand why I've got compression and water gets into the cylinders Thanks Steve Quote Link to comment Share on other sites More sharing options...
iantt Posted October 2, 2017 Share Posted October 2, 2017 nope, will have damaged bores, i take it you havent taken a head off an ecoboost 1.0 . not an easy job and lots of specialised tooling. 2 Quote Link to comment Share on other sites More sharing options...
Legacy7770 Posted October 2, 2017 Author Share Posted October 2, 2017 Time to drop the engine I think!! Thanks Steve 1 Quote Link to comment Share on other sites More sharing options...
iantt Posted October 3, 2017 Share Posted October 3, 2017 If your removing engine, you can leave gearbox,driveshafts,suspension all in place. Unbolt from gearbox,slide off input shaft and out from above. 1 Quote Link to comment Share on other sites More sharing options...
Legacy7770 Posted October 3, 2017 Author Share Posted October 3, 2017 Thanks again mate do you know the engine code?? The cars a six speed manual gearbox I think it's a 125ps. Yours sincerely Steve Evans Quote Link to comment Share on other sites More sharing options...
iantt Posted October 3, 2017 Share Posted October 3, 2017 If it's 125 then it's m1da Quote Link to comment Share on other sites More sharing options...
iantt Posted October 3, 2017 Share Posted October 3, 2017 Have you contacted a ford dealer to ask if ford will pay for a replacement engine? Quote Link to comment Share on other sites More sharing options...
Legacy7770 Posted October 3, 2017 Author Share Posted October 3, 2017 Thanks again your a star much appreciated. I bought the car as a non runner. Can someone please explain how water is finds its way into the cylinders?? Getting lost for direction Spark good Compression all 180psi Getting fuel As I said I'm new to the 1.0 ecoboost engine but thanks you guys I'm learning all the time. Yours sincerely Steve Evans Quote Link to comment Share on other sites More sharing options...
iantt Posted October 3, 2017 Share Posted October 3, 2017 warped head, headgasket , can still have good compression. Quote Link to comment Share on other sites More sharing options...
Legacy7770 Posted October 3, 2017 Author Share Posted October 3, 2017 Quick update guys. Drained all the coolant dryed the plugs it started right up. The coolant in the cylinders is all the same level. Is the inlet Manifold water cooled?? Yours sincerely Steve Evans Quote Link to comment Share on other sites More sharing options...
JW1982 Posted October 3, 2017 Share Posted October 3, 2017 The 1.0 ECOboost has a watercooled turbocharger and a watercooled exhaust manifold that is integrated into the cilinder head. I have seen before that a lack of coolant caused a turbocharger or cilinder head to crack. Quote Link to comment Share on other sites More sharing options...
Legacy7770 Posted October 3, 2017 Author Share Posted October 3, 2017 Thanks again guys anyone know if the inlet Manifold has any form of water cooling?? Thanks Steve Evans Quote Link to comment Share on other sites More sharing options...
