Battery Drain...
I'm shocked to see that no one mentioned the ALTERNATOR.  IF windings are shorted internally (e.g. field windings), that can drain the battery while-you-sleep.  I bought a minivan for CHEAP [with that problem] as the alternator can draw enough current to leave you stranded; dome lights, glove box lights really can't drain a good battery as quickly as an internally shorted alternator can 😉
  • Replies 50
  • Views 144.3k
  • Phil21185
    Phil21185
    Thanks for the reply.  Yeah, I understand the scopes of multimeters, but mine (a cheapy) jumps from 10A (which still displays 2dp), to 200ma but through the alternate positive port for the probe which
  • Executable code and static data (look-up tables or maps) would be stored in ROM and working data in RAM. I imagine the ROM, or at least some of it, is flash memory since it can be reprogrammed via the
  • not that it matters but that's the wrong setting, you want it 1A or 100mA setting 10A means the highest reading will be 10A, a value of 1 on this setting will be 1A your 0.01 is 10mA 1A will
