Guide For Focus Mk2/mk2.5 C-Max/kuga ~Elm 327 Cable And Ff2 Program
translating
2387 replies to this topic
#391 Preee
Preee
    Ford Fruitcake
  • 4,099 posts
  • Name: Paul
  • Ford Model: Focus Tit X Mk3 | Fiesta Zetec Mk7
  • Year: 2012
Posted 16 June 2012 - 08:28 AM
hi all im new to this i am trying to I tried downloading and opening the english version but it says
Component 'mscomm32.ocx' or one of its dependencies not correctly registered: a file missing or invalid
can someone help please
what i want to do is turn me air bag on and off and loads more i have the modded cable to do this all i need to know is what do i need to down loads
thanks anthony
Hi Anthony
What you need to do is go to this part of the thread and download the DLL pack and run , this will add the missing DLL files to your PC
http://www.fordowner...post__p__174711
Have something to contribute?
#392 Anthony Obrien
Anthony Obrien
    Member
  • Members via FB
  • PipPip
  • 23 posts
Posted 16 June 2012 - 05:01 PM
Hi Anthony
thanks but i have done this and its sill comeing up with this Component 'mscomm32.ocx' or one of its dependencies not correctly registered: a file missing or invalid
i downloads the dll to the desktop and run the REGdll.bat file it loads up and then goes off them i loads the ELM and it just comes up with Component 'mscomm32.ocx' or one of its dependencies not correctly registered: a file missing or invalid
#393 Preee
Preee
    Ford Fruitcake
  • 4,099 posts
  • Name: Paul
  • Year: 2012
Posted 16 June 2012 - 07:11 PM
Are you on Windows 7 64bit ?
rightclick the batch file and run as administrator.
If that fails then you will have to manually copy all 4 files to your windows/system32 folder , then goto the start/run and copy each of these in and hit OK
regsvr32.exe C:\Windows\System32\comdlg32.ocx
regsvr32.exe C:\Windows\System32\msvbvm60.dll
regsvr32.exe C:\Windows\System32\MSCOMCTL.OCX
regsvr32.exe C:\Windows\System32\mscomm32.ocx
If this does not work then also copy them to your 64 bit folder and change the regsvr32 lines to suit.
And lastly Right click and run the program as ADMINISTRATOR
This will also work for XP and Vista
#394 Teabags
Teabags
  • New Member
  • 50 posts
  • Name: DB
  • Ford Model: Focus ST
  • Year: 2009
Posted 17 June 2012 - 10:10 AM
Has anybody got a working link of elm-ff2 in English?
Thanks in advance
#395 Anthony Obrien
Anthony Obrien
    Member
  • Members via FB
  • PipPip
  • 23 posts
Posted 17 June 2012 - 06:23 PM
thanks mate i have done it now mate thank you for all your help mate
#396 darkyeh
darkyeh
    Newbie
  • New Member
  • Pip
  • 4 posts
  • Name: Bill
  • Ford Model: MK2.5
  • Year: 2012
Posted 20 June 2012 - 03:14 PM
Hello everybody,
how to trun on the steering system with elmconfig or elm ff2
like this link
where could find it ! thanks ....
#397 JW1982
JW1982
  • True Ford Enthusiast
  • 686 posts
  • Name: Wilco
  • Ford Model: Focus MK3 Champions Edition
  • Year: 2013
Posted 20 June 2012 - 06:03 PM
The steering settings are only available on all diesel versions and petrol versions from the 1.8 and above. These version have an electro hydraulic power steering system.
The 1.4, 1.6 and 1.6 TI-VCT versions have a conventional power steering system with a steering pump driven by the engine. with this system it is not possible to change sttings.
#398 Lenny
    Retired Moderator
  • 10,796 posts
  • Ford Model: Focus ZetecS
Posted 20 June 2012 - 07:08 PM
you guys are not missing much anyways,
sport setting means their is no power steering so you end up steering half a circle to turn a corner,
i keep mine in comfort mode all of the time, so its not much of a feature that you would change alot
#399 darkyeh
darkyeh
    Newbie
  • New Member
  • Pip
  • 4 posts
  • Name: Bill
  • Ford Model: MK2.5
  • Year: 2012
Posted 21 June 2012 - 01:44 AM
My Car is 1.8 petrol versions...(2011)
have EHPS (electro hydraulic power steering system)
at menu list could't see any steering system setting.
could use ELMconfig or FF2 to open it or not?
#400 Sliveredge
Sliveredge
  • Budding Enthusiast
  • 95 posts
  • Name: Peter
  • Ford Model: B-Max 1.0 125 titanium
  • Year: 2014
Posted 21 June 2012 - 05:14 PM
it is only there if the car has stopped.
#401 Preee
Preee
    Ford Fruitcake
  • 4,099 posts
  • Name: Paul
  • Year: 2012
Posted 21 June 2012 - 08:05 PM
It should be there to activate , also try checking the HEC page 2 (hec level) and adding sub levels up to 4 then you may see it in the menu.
As already stated car must be stationary before you cen change the setting.
#402 darkyeh
darkyeh
    Newbie
  • New Member
  • Pip
  • 4 posts
  • Name: Bill
  • Ford Model: MK2.5
  • Year: 2012
Posted 22 June 2012 - 01:30 AM
Tnanks reply ^_^ Preee :wub:
I have checked the HEC page 2 (hec level) and added sub levels up to 4.
Write, and restart this module.
But It's not work for me. :wacko:
Have any idea for me?
I didn't start engine.
Is this item need start engine? :(
#403 JW1982
JW1982
  • 686 posts
  • Name: Wilco
  • Year: 2013
Posted 22 June 2012 - 01:46 PM
Normally you must be able to change the settings in the menu when the engine is running and the car is standing still.
#404 Stoney871
Stoney871
    Resident Peacekeeper
  • Super Mod
  • 16,824 posts
  • Name: Clive
  • Year: 2007
Posted 22 June 2012 - 01:48 PM
Afaik the engine needs to be running but the vehicle stationary.
#405 darkyeh
darkyeh
    Newbie
  • New Member
  • Pip
  • 4 posts
  • Name: Bill
  • Ford Model: MK2.5
  • Year: 2012
Posted 22 June 2012 - 05:37 PM
It's not work :(
When engine running, the menu steering not appear :blink:
Anyone have any better suggestions ? :wub:
Not what you're looking for?
7 user(s) are reading this topic
0 members, 7 guests, 0 anonymous users
