Guide For Focus Mk2/mk2.5 C-Max/kuga ~Elm 327 Cable And Ff2 Program
#976
Posted 13 December 2012 - 01:40 PM
#977
Posted 13 December 2012 - 01:45 PM
In all honesty, I've probably neglected to do that.
When the cable arrives on loan from Lenny I shall take a closer look.
I don't even use the Eco mode, I just like lights coming on. I like to feel like I'm a pilot when I drive....
Modified Elm327 dispatch via tracked mail today mate,
Will arrive with you on tuesday 18th at the latest.
#978
Posted 13 December 2012 - 03:12 PM
Is there an option on the software to generate screenwash? Not kidding, have gone through 2 5l bottles since I've picked this car up
#979
Posted 13 December 2012 - 04:40 PM
#980
Posted 13 December 2012 - 04:43 PM
Ok i have re-added the uploads to ELM-FF2 English and FDS , if some one wants to test the downloads on Post 1 of this thread.
Working fine for me Preee .........
#981
Posted 13 December 2012 - 04:53 PM
Thanks Richie for testing
#982
Posted 13 December 2012 - 05:02 PM
#983
Posted 13 December 2012 - 05:26 PM
I did post a question on page 65.
#984
Posted 13 December 2012 - 05:31 PM
Can anyone suggest a reason why a modified device works fine on a Focus and very partially on a C-MAX?
I have never been able to to test on a C-Max so can't help sorry
#985
Posted 13 December 2012 - 05:35 PM
#986
Posted 13 December 2012 - 07:03 PM
Thanks for your reply. Are there any C-Max owners out there?
Good afternoon from Greece. I modified the adapter (per page 1 instructions ) and with ELMConfig i enable the autolock, instant concumption in my C-MAX pre-facelift model. Also i disable some features than previously were enabled by mistake with FORD IDS when were trying to enable cruice control.
Note : i use ELMConfig 0.1.2.1b version. (the previous one) . I have not test 0.2.3 yet....
#987
Posted 14 December 2012 - 08:37 AM
If you upgrade your washer jets to the mist type they will save your screen wash quite a bit.Cheers Len mate I got your PM just now.
And if you use cleaner in the tank instead of just waster then the mist jets turn it to foam which has great costic style cleaning results and will last much longer.
Check my fitting guide in the list below my post for fitting and to discuss this topic further in the mist jet fitting guide thread.
You may also require some new wiper blades to help clear the windscreen, fitting guide also in the below list.
#988
Posted 14 December 2012 - 09:21 AM
Dds
Autolock
Eco mode
Shift up
I have 3/4 of a tank and says i have 275 miles remaining. When i only get about 220 to a full tank normally
The mpg is right with about 21-23 mpg
#989
Posted 14 December 2012 - 09:26 AM
#990
Posted 14 December 2012 - 01:28 PM
Does anyone know why my distant to empty is miles out since i activated the following
Dds
Autolock
Eco mode
Shift up
It will settle down after a few fill ups.............don't worry.
