Guide For Focus Mk2/mk2.5 C-Max/kuga ~Elm 327 Cable And Ff2 Program
#991
Posted 14 December 2012 - 01:30 PM
#992
Posted 14 December 2012 - 04:46 PM
Nice one thought i did something that i shouldn't ofDaz it is because it resets to default. When you upload new settings. It will go along with your average fuel consumption and re learn as you drive.
#993
Posted 16 December 2012 - 07:11 PM
I already activate Eco Shift Up, the green arrow is there before I start the engine but it does not signal the shift change.
#994
Posted 16 December 2012 - 09:52 PM
#995
Posted 17 December 2012 - 08:00 AM
Eco mode is checked.
#996
Posted 17 December 2012 - 08:03 AM
#997
Posted 17 December 2012 - 06:02 PM
I need your help / clarification before and start the cluster update my Focus mk2.5 from 2009.
I have the rom 0243, can I update to 0509?
The ELM327 is set to 38400 bit / s baud rate. I have to change to another value or keep it?
If something goes wrong, the car is immobilized?
Thanks for your help and sorry for my English!
#998
Posted 17 December 2012 - 06:14 PM
The bit rate is ok, just leave it like that.
#999
Posted 17 December 2012 - 06:22 PM
to say I !Removed! myself is a understatement.
all the clocks were not working but you can still start the car.
just ran the update again and it was fine
#1000
Posted 17 December 2012 - 06:33 PM
#1001
Posted 17 December 2012 - 06:58 PM
The ECO shift up lamp is controlled by the PCM. It is possible that your versions of the PCM doesn't support this feature. The signal to turn on the shift light is missing in older PCM versions. Possibly a firmware upgrade of the PCM will solve this.
i have retrofiited the MK2.5 instrument cluster with firmware version 0509 to my MK2 (2005). on my car everything works fine including the ECO-mode feature. The only thing that isn't working is the ECO shift up light because of the missing signal from the PCM.
#1002
Posted 17 December 2012 - 07:17 PM
I think you are right. I'll just have to live without it
#1003
Posted 18 December 2012 - 09:25 AM
*patience...patience...*
#1004
Posted 18 December 2012 - 10:33 AM
#1005
Posted 18 December 2012 - 03:13 PM
Hello, please forgive my broken English.The ECO shift up lamp is controlled by the PCM. It is possible that your versions of the PCM doesn't support this feature. The signal to turn on the shift light is missing in older PCM versions. Possibly a firmware upgrade of the PCM will solve this.
I need your help and guidance.
I'm from China,my Focus mk2.5 from 2009,rom 0303, I want update to 0509 by ELMconfig .
The ELM327 is set to 38400 bit,But can not upgrade successfully.
May I ask how you did it, help me!
Thank you very much.
13 user(s) are reading this topic
2 members, 11 guests, 0 anonymous users
