Guide For Focus Mk2/mk2.5 C-Max/kuga ~Elm 327 Cable And Ff2 Program
#1036
Posted 29 December 2012 - 06:04 PM
The 4M5T modules are replaced by the 7M5T modules. You can't buy the 4M5T modules anymore from a Ford dealership.
I have searched for info for the part number of your GEM module but there is no info available anymore for this part number. Probably because it's an older part that is replaced bij the newer 7M5T module.
#1037
Posted 29 December 2012 - 06:33 PM
Do all 7M5T units work with cruise control?
FuF.
#1038
Posted 29 December 2012 - 06:42 PM
I purchased a cable last week and stupidly rushed in and added the switch before testing. I didn't have time or daylight over christmas to try it on the car and have run into a bit of a problem.
When I attached the cable to the car and run ELM-FF2 I receive a CAN ERROR (below). I assumed that I has wired the switch up incorrectly. However, on returning the cable to its original state I still receive the same error when attempting to read the configuration. Any ideas?
It may be that the laptop I'm using is the problem - fresh Win 7 install. However, I have the drivers installed, com port set and bit rate set at 38400.
I have 2 other laptops I can try - Win 7 and old XP if that helps??
Thanks in advance
* ŒÚÍ˚Ú ÔÓÚ COM3
* ◊ÚÂÌË ÍÓÌÙË„Û‡ˆËË ËÁ ÏÓ‰ÛΡ IPC (Control panel)
> ATZ
< ELM327 v1.5
> ATSP6
< OK
> ATSH720
< OK
> 1087
< CAN ERROR
! ÃÓ‰Ûθ Ì ÓÚ‚ÂÚËÎ ËÎË ÓÚÒÛÚÒÚ‚ÛÂÚ
* ◊ÚÂÌË ÍÓÌÙË„Û‡ˆËË ËÁ ÏÓ‰ÛΡ BCM (GEM ÏÓ‰Ûθ) [◊‡ÒÚ¸ 1]
> ATZ
< ELM327 v1.5
> ATSPB
< OK
> ATSH726
< OK
> 1087
< CAN ERROR
#1039
Posted 29 December 2012 - 07:18 PM
Can Error is usually when it's in the incorrect switch position , so if you cable is not working in original position under HEC then switch the two wires , it then it works you can go back to wiring it correctly.
But the fault is not the PC or windows 7
The switch in Original State will Read and write to HEC module, wired in switch will allow it to Read and Write to GEM.
#1040
Posted 29 December 2012 - 07:26 PM
Thanks - that's really helpful.
FuF.
No, the lower spec GEM modules don't support Cruise Control.
It is very difficult to find out which part numbers do support Cruise Control.
I have got a GEM module with part number 7M5T-14A073-JF and this one definately supports Cruise Control.
#1041
Posted 29 December 2012 - 08:15 PM
#1042
Posted 29 December 2012 - 08:36 PM
I'll switch the connectors round and retry in the morning
Stu
You may have wired it incorrect in the beginning and then returning it to original state you may have the wires the wrong way around.
#1043
Posted 30 December 2012 - 07:13 AM
Is there still any way to reprogram PCM module for cruise control myself or is only way to do it to bring my car to Ford mechanic who does have Ford IDS and is willing to use it? I got quote of EUR 150 for reprogramming the module which seems a bit high price for me (unless they guarantee results for that price and fix everything if something goes wrong).
The only way to activate Cruise Control in the PCM is to reprogram the PCM with IDS or another suitable diagnosis interface that can perform software updates. It is not possible to do it yourself unless you own the proper equipment.
#1044
Posted 30 December 2012 - 10:24 AM
While I new my soldering was good I did not count on the plastic pin connector (to board) to be the wrong way round from factory. When I removed the connector from the board I did not make a note of its orinetation and used an image from the start of the thread. This meant that my cable would not work as the pins were all incorrect.
I've just managed to connect and save down a few options from the IPC tab - I'll need to rewire a new switch (as I destroyed the last one.... ) and I should be good for BCM
My cable came from the same supplier linked on the first page of this thread - However, the PCB inside had a different layout so double check when you put yours back together
Stu
Thanks - all I can think is I've perhaps put the connector back on the board the wrong way (changing the pin layout)
Stu
#1045
Posted 30 December 2012 - 10:59 AM
#1046
Posted 30 December 2012 - 04:22 PM
Hows the elm327 modifications working for you mate?Main thing I want to do is enable cruise control and ensure it doesn't cause any havoc - I don't have the other parts to do the rest of the mod yet, but enabling it is one hurdle (assuming it isn't one of the cars which has to go to ford, only for them to smile and say no.)
Will keep you posted.
Did you enable RDS in the centre screen and eco mode display?
#1047
Posted 30 December 2012 - 10:57 PM
#1048
Posted 31 December 2012 - 12:47 PM
#1049
Posted 31 December 2012 - 03:03 PM
Being able to activate Cruise control configuration in GEM with the ELM cable means the GEM supports Cruise Control?
#1050
Posted 31 December 2012 - 06:32 PM
Latest Comments
More
