Guide For Focus Mk2/mk2.5 C-Max/kuga ~Elm 327 Cable And Ff2 Program
translating
2396 replies to this topic
#1231 s90jny
s90jny
    Newbie
  • New Member
  • Pip
  • 7 posts
  • Name: bobby
  • Ford Model: focus rs mk2
  • Year: 2009
Posted 23 March 2013 - 12:01 PM
Was you using bluetooth ?
Have you tried connecting , then selecting procedures and reseting the module
Did you do the number one Golden rule and Backup ? , if you did try reloading the backup and writing
no i wasnt using the bluetooth.
i have tried all methods available - under the hec tab it says no data(like it does with the ignition off)
yes i have back up..... but they cant be written to it due to the no data warning
Have something to contribute?
#1232 Preee
Preee
    Ford Fruitcake
  • 4,124 posts
  • Name: Paul
  • Ford Model: Focus Tit X Mk3 | Fiesta Zetec Mk7
  • Year: 2012
Posted 23 March 2013 - 12:23 PM
Off the top of my head the only thing i can think of is remove the battery for 15 minutes see if it resets
#1233 nuno8210
nuno8210
  • Budding Enthusiast
  • 49 posts
  • Ford Model: Focus
Posted 23 March 2013 - 01:32 PM
From what I already saw and what I have eard the safest way is to get away from Page 3 of the HEC configuration... Even reading from unit is dangerous and you can't have a backup of that before reading it...
If the battery reset doesn't work I guess the only option will be a Ford dealer to update your HEC. Let's hope that a new HEC is not necessary...
#1234 Richiemac
Richiemac
  • 194 posts
  • Name: Richard
  • Ford Model: Focus 2014 1.6 tdci + S max 2011
  • Year: 2014
Posted 23 March 2013 - 01:39 PM
Disconnect the positive lead from battery and hold it to the negative pole for a bout  5 minutes to totally discharge all residual current.........reconnect and hopefully should restart.
#1235 s90jny
s90jny
    Newbie
  • New Member
  • Pip
  • 7 posts
  • Name: bobby
  • Year: 2009
Posted 23 March 2013 - 01:42 PM
is this not dodgy to do?
#1236 Richiemac
Richiemac
  • 194 posts
  • Name: Richard
  • Year: 2014
Posted 23 March 2013 - 01:48 PM
Yes, positive lead will be disconnected from battery....not like if you bridged across them with it connected, then you'd do damage.
#1237 s90jny
s90jny
    Newbie
  • New Member
  • Pip
  • 7 posts
  • Name: bobby
  • Year: 2009
Posted 23 March 2013 - 01:52 PM
gotya
#1238 jeebowhite
jeebowhite
    Resident Loon
  • Super Mod
  • 19,763 posts
  • Name: James
  • Year: 2007
Posted 24 March 2013 - 07:13 AM
Thanks Wilko, I own the MK1 Focus CMAX. I have been helping a few friends with a MK2 Focus.
Bobby... have you managed ot make any progress?
#1239 JW1982
JW1982
  • True Ford Enthusiast
  • 702 posts
  • Name: Wilco
  • Ford Model: Focus MK3 Champions Edition
  • Year: 2013
Posted 24 March 2013 - 08:10 AM
The Focus C-max MK1(.5) is technically pretty much the same car as the Focus MK2(.5). Most of the wiring and modules are completely the same.
One difference is that Ford did not offer the DDS option on the C-max MK1.5 The C-max MK1.5 has (from a certain production date) exactly the same instrument cluster and ABS pump/BCM as the Focus MK2.5. Technically the C-max MK1.5 is perfectly able to show the DDS option in the instrument cluster but this is blocked in the C-max software/firmware.  On a Russian forum i found a topic of some guys who configured (with the Ford IDS system) a C-max MK1.5 like the Focus MK2.5 to activate the DDS option.
#1240 s90jny
s90jny
    Newbie
  • New Member
  • Pip
  • 7 posts
  • Name: bobby
  • Year: 2009
Posted 24 March 2013 - 08:20 AM
Yes disconnecting the battery solved half the issue. I then had to reset 2 fault codes before the kuga would start. thanks for the help
#1241 Preee
Preee
    Ford Fruitcake
  • 4,124 posts
  • Name: Paul
  • Year: 2012
Posted 24 March 2013 - 02:04 PM
Glad to hear it worked , always a good option if everything else fails
#1242 laurashgeo
laurashgeo
    Member
  • PipPip
  • 10 posts
  • Name: George
  • Ford Model: Focus 2.5
  • Year: 2011
Posted 25 March 2013 - 04:57 PM
I cant get my ELM cable to work on windows 7! each and every time it comes up with a code 10 error and the device will not start. plugged it into a XP desktop and works fine.
any help please??
Hello!
I received my Elm327 today(bought from China on ebay) and I have the same error.
I was reading on Prolific website and I found this:
!!!Counterfeit Warning!!!
Please be warned that counterfeit/fake PL-2303HX Rev A (or PL-2303HXA) USB-to-Serial Controller
ICs using Prolific's trademark logo, brandname, and drivers, are being sold in the China market.
Counterfeit IC products show exactly the same outside chip markings but generally are of poor quality
and causes Windows driver compatibility issues (Yellow Mark Error Code 10 in Device Manager under
WinXP, Vista, and 7). This warning is issued to all customers and consumers to avoid confusion and
false purchase. Please purchase only from stores or vendors providing technical and RMA support.
What can I do?
#1243 Preee
Preee
    Ford Fruitcake
  • 4,124 posts
  • Name: Paul
  • Year: 2012
Posted 25 March 2013 - 08:41 PM
Download Drivers from here
http://www.totalcard...e&kbarticleid=1
The ELM327 works fine with these drivers , that is a generic response you have found on the web.
#1244 laurashgeo
laurashgeo
    Member
  • PipPip
  • 10 posts
  • Name: George
  • Year: 2011
Posted 26 March 2013 - 05:08 PM
Thanks for the link, but it's still not working :( I tried also with this driver http://www.prolific...._id=225&pcid=41 and I have the same error.
Yesterday I received the Auto Diagnostic and I Tried all day to make it working, but I didn't manage.
I manage to install the driver but when I am plugging the cable I get a error that tells me that the device is not working properly. In the device manager I have this error: This device cannot start. (Code 10)
I am using a Windows 7 Ultimate on 64bit and I was trying to install the Auto Diagnostic on my desktop with Windows 7 Home Edition.
Do you have any other suggestions? I will try soon on a friend's laptop with windows xp installed.
LE: I bought it from here http://www.ebay.co.u...E:X:RTQ:GB:1123 so try to avoid this seller!
#1245 mrmetallica
mrmetallica
  • 332 posts
  • Name: john
  • Ford Model: focus titanium 1.6
  • Year: 2009
Posted 26 March 2013 - 06:08 PM
i dont think it likes 64 bit
Not what you're looking for?
3 user(s) are reading this topic
1 members, 2 guests, 0 anonymous users
