Stu9 Posted May 2, 2015 Share Posted May 2, 2015 On an 03 1.8 tdci It's the pipe at the turbo as I can't get leverage on the nuts under the egr Quote Link to comment Share on other sites More sharing options...
Stu9 Posted May 2, 2015 Author Share Posted May 2, 2015 I felt some difference but there's now diesel fumes inside....I've never had that before blanking an egr unless it needs to be done from the unit itself...I'll take the plate back out and leave as is till if/when I can get the nuts under it off Quote Link to comment Share on other sites More sharing options...
Stu9 Posted May 2, 2015 Author Share Posted May 2, 2015 Now I've got something weird with the bolt at the back (in the photo) it loosens so far then gets stuck, now I've always know the when you heat nuts and bolts they generally come off easier....not that one!. Unless the threads are caught on a bit of the tin plate I put round it, if that's the case I'm buggered if I know what to do now as I can slide it out, it's folded round the original gasket so need to get it out.....got a dilema now Quote Link to comment Share on other sites More sharing options...
Stu9 Posted May 2, 2015 Author Share Posted May 2, 2015 Can anyone shed any light on this......I thought someone would have said something, I know I'm used to faster moving forums but I thought since early afternoon and 40odd views someone would have known something Quote Link to comment Share on other sites More sharing options...
Stu9 Posted May 2, 2015 Author Share Posted May 2, 2015 It's a waste of fkn time here it really is Quote Link to comment Share on other sites More sharing options...
TomsFocus Posted May 3, 2015 Share Posted May 3, 2015 Maybe it's not a problem anyone has encountered before...sounds like something you've added anyway lol? Tbh it sounds as if you've crossthreaded it? Not sure what the access is like but try pulling it while unscrewing it, molegrips or a small prybar may help? 1 Quote Link to comment Share on other sites More sharing options...
