PAINTMODZ Shark Fin for Mk3
On 19.04.2018 at 10:02 AM, Furio101 said:
I tried the stubby, certain parts of my journey DAB did not work. Swapped back to original and it works perfectly. I have now ordered the 2017 aerial to see what that one is like.
Sync 3 completed week ago mate
  • Replies 63
  • Views 22.2k
  • I will just refresh the topic 🙂 The Shark Fin off the new Focus MK4 with GPS has the finish no. : 2281582  I will might try tis one beg. of next year.
  • mastachaz
    mastachaz
    dab not working
  • If you want a sharfin antenna with decent radio and GPS reception you should buy the original 2015 lincoln MKC / 2015 Ford Edge sharkfin antenna. this sharfin antenna is a direct fit to the Focus MK3/
Is it straight forward to do? And is there much difference as that may be my next project lol.
Sent from my SM-N950F using Tapatalk
little bit
could you open your fina and post photos? maybe somehow we will be able to switch with base on car. I didget same- no wires but refuse to collect.
Hi mate I opened it up after I got it, it is just a empty space inside, so all it really is, is a metal plate with a cover on it.
Thanks , so hmm not good we habe other parts then people in USA . Are you ale to cover base with this ?
Would need to try and get the base to fit inside which is my next project and maybe try and shape a long aerial into a spring kind of idea applying heat to try and get it to fit inside.
In this case its same as paintmodz cost same and have to paint
I decide to keep paintmodz for now.
I'm trying to get another paintmodz one since my Mrs is ok so if I can get a new one hopefully it works ok as my last one wasn't good on my car but my Mrs one I got was perfect.
I did test dab on mine works 99% of time. In london not sure how will be somewhere else but then I have MP3
Yeah my Mrs paintmodz one is fine in Glasgow but mine is terrible putting it down to a poor connection and going to get another one for mine.
  • 3 months later...
The Shark Fin off the new Focus MK4 with GPS has the finish no. 2281582
If you do try it and it works let me know as I would probably change it again if it did work lol.
