Adaptive Headlight Warning on Dash
bluepeter
 Share
20 hours ago, TomsFocus said:
There is a third option, though it's not widely done yet!
You can get an electronics repair company to replace whichever internal component is broken.  Very common with other parts such as dash clusters etc.  It still won't be cheap, but much cheaper than a brand new unit and will be warrantied, where a used unit often isn't.
Excellent suggestion. Any recommendations for a company in the Cambridge area? I wouldn't know what type of company would take this on...
Link to comment
These places are quite few and far between so generally have to send the part to them for repair.  You might find a local place through Google but BBA Reman is the place I'd recommend.
Link to comment
Wow Trust Pilot is not a friend of BBA Reman.
https://uk.trustpilot.com/review/shop.bba-reman.com
Thanks for the suggestion, it's a good shout - I'll see if there is a local option for me.
Link to comment
Are they a fan of anyone?  You wouldn't buy a Ford if you looked at the Trust Pilot ratings. :biggrin:   https://uk.trustpilot.com/review/www.ford.co.uk
Do let us know if you find somewhere reputable so I can change my recommendation though.  Genuinely haven't seen any complaints about BBA on here.
Link to comment
Ha, very good point!
I'll keep the forum posted on progress. Thanks to all for the advice.
Link to comment
  • 3 weeks later...
Hi I've sat reading all your comments with regards to this "check adaptive headlamps " sign . I have an S-Max Vignale 66 plate . Purchased 2017 all was fine until Aug 2019 when the sign kept coming up booked into DEALER we purchased car from and a diagnostics determined a new headlamp module was needed on drivers side that was replaced under warranty.... which then expired beginning October 2019 10 days after this the sign came up again its not constant maybe on for 3 times I start the car then clear , but they had the car back November 2019 to then tell us Passengers side whole headlamp unit needs replacing at a cost of £1242. Inc fitting and vat . I then contacted Ford customer relations and they have agreed to pay towards the cost of repair,  I have to pay £400 towards it . But this sign hasnt been on constantly and we recently took a weeks holiday and left the light setting switch to the adaptive position and not once in 10 days did the sign come up . Tuesday 6th October had my MOT and they turned the light switch back to the off position,  I came out of waiting for my car and started it up and now the signs back again intermittently,  I am back in touch with Fords and its going to be booked in for the headlamp to be replaced,  but If the sign reappears I'm not going to be happy .
Link to comment
hello, I had my headlamp replaced just before my warranty ran out because of the intermittent warning. Same as you i had a module replaced and wiring checked etc over months and months. Ford uk authorized the new headlamp as my local dealer was reluctant to put a new one in, incase it failed again. I was told that they would honour the problem after the warranty finished if it was still there. Thankfully everything is working great since replacement.
Link to comment
  • 2 months later...
Hi
do you have just one headlamp replaced? the other will follow soon or later, if its happen like mine, it was later, yes, out of warranty, happen exactly one year after one been replaced, and now?? don't understand why, with some many cases, Ford don't get responsibility for the problem....
Link to comment
21 hours ago, tikoo said:
Hi
Hello'
yes i just had the one headlamp replaced. I asked about the other side but they wouldnt change that one. I'm hoping that it will stay ok but time will tell. Everything is still working fine since being replaced. Your right  i think that Ford should take responsibility too if the problem reoccurs. Here's hoping it doesn't.
cheers
Link to comment
I had mine (a single headlamp) replaced I'm guessing a couple years ago now. Went out to the car couple days ago and the dreaded message popped up. Check adaptive headlamps. Nothing I can do now it's out of warranty apart from shedding £1,000+ 😕
Link to comment
  • 1 month later...
FFS !!!! Its back !!!!
Had approx 30mths of trouble free headlights, but now that dreaded warning is back !
Booked in for a service in 2 weeks, so will report it then, and see what happens this time
Link to comment
I had the warning flash up today on my new Kuga. Cornering function of adaptive lights wasn’t working. I stopped the car, switched off, locked and unlocked the doors and started up again. It did its wibble wobble up and down thingy and all working again. Hopefully just a gremlin in my case. I had a few irritating gremlins with the Edge electronics, but no issues that needed work on them, so hopefully the Kuga will be the same.
Link to comment
  • 4 weeks later...
  • 8 months later...
I am having this issue with my 2017 Edge Vignale.  My car is outwith the warranty period (only started happening after the warranty was up).  The warning was showing intermittently, now its every time I drive the car but only shows up part way through the journey.  Some of the roads I drive have no lighting and the car is automatically going into follow me home lighting mode (which is pretty dangerous as you can't see too far ahead of you).  Is there any other way to rectify this problem as I don't fancy paying the prices to have a new light unit installed at over a grand....!!!!!!
Link to comment
Can you explain further ?  Are you referring to cornering lights ?
Generally the term follow me home lights (an Americanism) refers to the headlights remaining on for a period of a minute or two after you park so that you can see your way home to the front door.
Link to comment
  Only 75 emoji are allowed.
 Share
  • Create New...
Forums
News
Membership
