Mk4 focus 1.0 125 Engine rattle
17 hours ago, Rf29 said:
Hi, I have the same problem since 20k [now26k] , and the dealer say it's normal.
Not sure which one of the noises you have, if it was the first one in the video this was replaced under warranty as there was play in the clutch
If its the second one which sounds like a high pitched rattle when engine breaking this was also sorted under warranty, this was the wastegate on the turbo had too much play in
  • 1 year later...
  • Replies 51
  • Views 22.4k
  • The 1.0 ECOboost in the Focus MK4 does not have a dual mass flywheel. The Focus MK4 1.0 ECOboost has the MX65 gearbox combined with a solid flywheel. The MX65 gearbox is a modular design that inc
  • Connorfinn
    Connorfinn
    Hi guys,    Managed to get the ford mechanic to hear the noise after 2 trips at the dealer The car is booked in to the garage in 2 weeks time for a gearbox replacement at 14,000 miles
  • Connorfinn
    Connorfinn
    Hi guys Finally got my car back from ford They ended up replacing the clutch and flywheel as the clutch bearing had about half an inch of play   Hope this helps anyone else 😊
I have a 70 plate focus 1.0 ecoboost 125 only rattles/knocks when I accelerate any help please
