kmoore04uk Posted April 9, 2022 Share Posted April 9, 2022 Hi all, a while ago there was a thread on here for increasing the battery charge rate using forscan to increase the actual battery charge to near 85/90% For the life in me I can't find this thread. Does anyone know how to do it, if so then please let me know. Cheers Quote Link to comment Share on other sites More sharing options...
ianincheshire Posted April 9, 2022 Share Posted April 9, 2022 I think it was this thread Quote Link to comment Share on other sites More sharing options...
Nathan Buffery Posted April 9, 2022 Share Posted April 9, 2022 I couldn't find the option, within Forscan, to alter the state of charge on my focus which is a mk 3. 1 Quote Link to comment Share on other sites More sharing options...
JW1982 Posted April 9, 2022 Share Posted April 9, 2022 Not possible on a Focus MK3/MK3.5. The maximum State of Charge is not configurable on this type of vehicle. 2 Quote Link to comment Share on other sites More sharing options...
kmoore04uk Posted April 10, 2022 Author Share Posted April 10, 2022 Thanks for your replies. Looks like I have to buy a new battery then. I like the start/stop and it really annoys me that I can't use it. My focus has just about every extra. Including something as silly as automatic retractable door protectors (which I have never seen before) but they forgot to make the rear brakes disc instead of the drums as they are. How stupid is that? Quote Link to comment Share on other sites More sharing options...
Don Ridley Posted April 28, 2022 Share Posted April 28, 2022 Does your Focus have a battery monitoring system (BMS)? If there is a module on negative cable clamp assembly (at the battery), you have BMS. BMS limits the state of charge (SOC) to about 80% for fuel efficiency. You can turn BMS off in Forscan (BdyCM main section). Or you can disconnect the small wire attached to the currect sensor on the cable. This will not increase the rate the battery charges (volts and amps), but it will increase the SOC if BMS is limiting it. As the battery ages the SOC will drop. You can also monitor SOC using Forscan. 1 Quote Link to comment Share on other sites More sharing options...
Nathan Buffery Posted April 28, 2022 Share Posted April 28, 2022 5 hours ago, Don Ridley said: You can turn BMS off in Forscan (BdyCM main section). Or you can disconnect the small wire attached to the currect sensor on the cable. Interesting. Have you done this yourself? I'm wondering if this will effect anything else on the car. I think my preferred option would be to turn it off in Forscan as I reckon disconnecting the wire will cause a DTC. 1 Quote Link to comment Share on other sites More sharing options...
Wino Posted April 28, 2022 Share Posted April 28, 2022 6 hours ago, Don Ridley said: Does your Focus have a battery monitoring system (BMS)? If there is a module on negative cable clamp assembly (at the battery), you have BMS. BMS limits the state of charge (SOC) to about 80% for fuel efficiency. You can turn BMS off in Forscan (BdyCM main section). Or you can disconnect the small wire attached to the currect sensor on the cable. This will not increase the rate the battery charges (volts and amps), but it will increase the SOC if BMS is limiting it. As the battery ages the SOC will drop. You can also monitor SOC using Forscan. It's a shame the SOC can't be added to the dash screen like the auto lock can. Quote Link to comment Share on other sites More sharing options...
Don Ridley Posted April 29, 2022 Share Posted April 29, 2022 21 hours ago, Nathan Buffery said: Interesting. Have you done this yourself? I'm wondering if this will effect anything else on the car. I think my preferred option would be to turn it off in Forscan as I reckon disconnecting the wire will cause a DTC. Yes. Turning off the BMS simply makes the charging system behave like every other vehicle. The PCM will control the alternator output to maiximize the battery charge. Quote Link to comment Share on other sites More sharing options...
JW1982 Posted April 29, 2022 Share Posted April 29, 2022 Disabling the BMS also requires a different battery. When the BMS is disabled the PCM is programmed for the charging characteristics of a Silver/Calcium battery and not for the EFB battery that is used on a Ford with BMS. 1 Quote Link to comment Share on other sites More sharing options...
Nathan Buffery Posted April 29, 2022 Share Posted April 29, 2022 Might be a stupid question, but is the small box shaped thing on the negative battery terminal the actual BMS, or is it just part of the system? Quote Link to comment Share on other sites More sharing options...
unofix Posted April 29, 2022 Share Posted April 29, 2022 2 hours ago, Nathan Buffery said: is the small box shaped thing on the negative battery terminal the actual BMS, Yes. Not much to look at. Quote Link to comment Share on other sites More sharing options...
Wino Posted April 29, 2022 Share Posted April 29, 2022 51 minutes ago, unofix said: Yes. Not much to look at. Didn't someone post about it a while ago suggesting that's some Fords were fitted with the wrong one ? Quote Link to comment Share on other sites More sharing options...
unofix Posted April 29, 2022 Share Posted April 29, 2022 16 minutes ago, Wino said: Didn't someone post about it a while ago suggesting that's some Fords were fitted with the wrong one ? OK David, you got me !! 🤣 Watch the video (2:34) for details on the BMS. I think it only effects the Focus Mk4 1 Quote Link to comment Share on other sites More sharing options...
Don Ridley Posted April 29, 2022 Share Posted April 29, 2022 8 hours ago, JW1982 said: Disabling the BMS also requires a different battery. When the BMS is disabled the PCM is programmed for the charging characteristics of a Silver/Calcium battery and not for the EFB battery that is used on a Ford with BMS. You can also change the battery type in Forscan but I don't know if there are options for EFB, Silver Calcium and/or AGB. The battery labels (abbreviations) in Forscan are not defined. Quote Link to comment Share on other sites More sharing options...
