2009 1.4tdi injector coding?
Hi all, Newbie just joined looking for some assistance please...
I have a 1.4 tdci which was running really rough, had the injectors cleaned, and 1 replaced, now they're back in its worse!!!
They are back in the right cylinders, do i need to get the new one recoded? its a siemens injector.
I would appreciate any advice on this?
You really need @iantt or @TomsFocus to answer the question on do Siemens injectors need coded.
All I can say is that if they do then download FORScan and you will be able to do it.
FORScan: https://forscan.org/download.html
ELM327(modified) connecting lead: https://tunnelrat-electronics.fwscart.com/USB_Modified_with_switch_ELM327/p4541936_17045457.aspx
They should adapt eventually without coding but it's better to code the new one where possible.  Can be done yourself with Forscan as above.
