P0130
Good evening,
I've tried alot of different solutions in order to fix this error code - bank 1 sensor 1 (o2 Sensor)
It's a 2005 ford fiesta 1.25
Things I've tried -
  • Changed spark plugs
  • Checked for exhaust leaks and changed the rear silencer
  • Changed the oil filter
  • Changed the air filter
  • Changed the o2 sensor on bank 1
  • Cleared the error code
What else could it possibly be?
Wiring between the sensor and PCM.
there is a voltage so i believe the wiring is in working order. @TomsFocus
Does the output voltage change throughout the rev range?
On 6/17/2024 at 12:07 PM, james29304 said:
Good evening,
Things I've tried -
Hello there, sounds like the Lamda sensor on the exhaust has failed
