Focus Titanium Mk2.5 (2010) - Bluetooth unit?
On 10/4/2024 at 10:51 PM, Throbber said:
Downloaded the latest EML but get the error attached when trying to run? - AH got it, run as admin 🙂
you need a runtime pack of Microsoft gibberish you install first (usually in the same download location)
as for more exciting stuff - the cable (if you got the Vgate 18V feps one) will stand you in good stead to use Forscan - a more complex tool - free for basic stuff - but playing with keys you need to buy windows system big boy version - still cheap but only a single year license these days....
https://forscan.org/download.html
On 10/6/2024 at 8:53 AM, tommy1340millar said:
Throbber - I'm late to this party!
I'm in Stirling. My last mk 2.5 Titanium came without Bluetooth, so I retrofitted.
There was definitely a lot more cables with some convoluted routing compared to my mk2 😮
Anyhow - bottom line. I bought the USB/aux panel from inside console cubby box (didn't get round to installing it, my car had all the wiring under the dash for it, but I'm pretty sure there was a small jumper loom needed too)
If it's any use to you, you can have it for the postage. (I bought it on ebay for £25, but it's lying here doing nothing. Current mk3 already has one)
drop me a pm .
Tommy
cheers for offering mate ok at the moment! 🙂
Just been trying to do the config.
I can access the car module via FORScan but get the following error for EML
image.thumb.jpeg.c447acb2a33d9374923e8952ac6ab22d.jpegimage.jpeg.714c18c92666a1dcb9fba8f75e93e433.jpeg
Have tried Baud rate at 36000 too.
..have you got the basic set up set to a focus ? pick the wrong one and its always mental
did you do the adapter set up bit at the bottom and always without this tool in the way - update its brain using the latest firmware first
updated the adapter firmware to the latest version - 2.3.02
did the adapter set up part also but still the same message....
well either the runtime pack isn't there... or some silly little set up issue needs fixing - add the run time bundle - then reinstall ELM config - and then check in windows device manager with just the cable in the laptop
don't forget every month Microsoft does its utmost to destroy windows - rebuilding / reconfiguring things wrong, adding something no one ever wanted and removing vital stuff you definitely did
I don't think the cable is too clever for that software - but might as well try the free version of Forscan
