Start/Stop? is it fitted
Hi, my daughter has a 2019, 1.6 Focus, the V5C shows it as a Titanium X Auto, Euro 6 AG
She is having issues with the battery going flat.  I have been looking at the best place to buy a replacement but every place I check only shows Batteries that are for Start/Stop fitment but she says that she does not have this feature.  I cannot get access to the car until next weekend so cannot have a good look over but I have not noticed a similar button to that in my wife's Fiesta.  Is there a way to find out the facts about this car, a vin/vrn decode?
regards
She doesn't, there is no 1.6 auto by 2019 only 1.0
A 2019 Focus would have stop start
Thanks, but all battery options from the normal online retailers show only a start/stop fitment
for instance, this is the only battery that Halfords list
https://www.halfords.com/motoring/batteries/car-batteries/halfords-efb100-start-stop-car-battery-5-year-guarantee-255854.html
It won't be a 1.6 Focus at 2019.  It'll be 1.5.  Is it petrol or diesel?
There should be a button like this, bottom left, if it has SS fitted.
Misc Controls
You can also put the reg into this website for a free check.  Just scroll down past the 'paid for' stuff.
Free BHP Check - Total Car Check
Yes, you are correct, it is a 1.5.  According to that site it does have Stop/Start
Your daughter is almost correct stating it doesn't have the stop/start feature. There are 100s of threads on this forum dealing with that system not working. It's one of the worst things Ford ever tried to introduce, and they only developed it to aid them passing some emission testing for new cars and trying to save the odd dolphin.
It's very fragile, and often doesn't work in cars it is fitted. Many here simply ignore it not working as a blessing in disguise. Remember when you were a kid, flicking a light switch on/off/on/off before getting shouted at by a parent telling you to stop that, you'll break it!
Similar concept except now you have a whole engine stopping/starting whenever it feels like it.
If you do get a replacement battery, and start/stop doesn't operate as expected, don't give it a second thought. Most drivers can turn the engine off themselves when needs be...
The best suited battery for the Focus Mk4 (2019) is the Yuasa
Yuasa YBX7096 12V 75Ah 700A
This is the largest capacity battery that will fit the standard battery tray.
Best price is usually from: https://www.tayna.co.uk/car-batteries/yuasa/ybx7096/
Fit the new battery, reset the BMS and up the max charging rate to 95% using FORScan and you won't have anymore issues.
Fully charge the new battery before fitting
Perfect advice from Dave (above post).
BMS reset after the new battery fitted:
On 3/29/2023 at 8:14 PM, unofix said:
How to reset the BMS method 2        Search Tag: BMS2
Ok, well she deff does have Start/Stop, she said not, but I fitted the halfords battery today and the button is there.  Whats the best way to up the charge rate as my wifes Fiesta STline charges to 12.28v max due to the way Ford set the charging Or is this not really an option when they have start/Stop?
 Whats the best way to get ForScan? I have the CR Pro for general stuff and OpScan for my Insignia VXR.  Also still have MB DAS/Xentry from when I had a Mercedes so not scared of diving a bit deep as long as I am armed with some info.
24 minutes ago, miffy said:
 Whats the best way to get ForScan?...
I'm sure @unofix will be along soon to advise...
Ask and thou shalt receive 👍     -  Quote from Lord Alli to Sir Keir 🤣
On 4/7/2024 at 8:59 PM, unofix said:
FORScan (for use with Windows Laptop) : https://forscan.org/download.html
It's what many Ford owners use including some Ford technicians.
vLinker FS, cable for laptop: https://www.amazon.co.uk/Vgate-vLinker-Adapter-FORScan-MS-CAN/dp/B0952P4MLP
vLinker FD, for android phone: https://www.amazon.co.uk/Vgate-Bluetooth-vLinker-Scanner-Diagnostic/dp/B08H82WC8L
vLinker FD+, for iPhone: https://www.amazon.co.uk/Vgate-Bluetooth-vLinker-Scanner-Diagnostic/dp/B08H8JHWP2
Search Tag:   FORScan123
Is the elm 327 no good with forscan just seen this lead
The ELM327 lead is not suitable for vehicles 2013 onwards. It will partly work on some models but programming functions of newer cars may fail.
Use the vLinker FS cable and a Windows Laptop.
thanks @unofix I have just bought the lead you suggested.  Is there a guide on how to set the charging rate to 95%?
Not that I've seen.
Just search 'State Of Charge' in the BCM and you should easily find it.
vLinker arrived today, is that your amazon shop btw?
I wish, but no 🤣
1 minute ago, unofix said:
I wish, but no 🤣
That's a shame, thought you might be able to shift some of my MayPoles through it 🤣
Cheeky 🤣🤣
Had a go with Forscan and I don't have any options related to charge levels in the BCMii but it does look like I can code out start/stop
Check on the FORScan forum. I don't think you can
You would be the first to succeed at doing that. Please post back if you manage to do it, there are many here that would love to get rid of Stop/Start
And on the FORScan forums
Yep, as I thought, Stop/Start cannot be deactivated only remapped out, by a specialist, if you can find one
