Battery Resting Voltage
On 6/26/2025 at 1:12 PM, unofix said:
Well there's a collection of words that you don't often see in the same sentence 🤣
Unless you are talking to me, of course.
  • Replies 52
  • Views 4k
  • Eric Bloodaxe
    Eric Bloodaxe
    Unfortunately I'm old enough to remember when dynamos were still commonplace and alternators were replacing them.  With a dynamo, at idle, you would often see the charge light flicker, or get a z
  • Well there's a collection of words that you don't often see in the same sentence 🤣
  • It will need to be charged for a minimum of 12 hours before it is fitted to your car.
Hi Mike,
Funnily enough I've just got off the phone from Ford CRC, and the person dealing with my case has left the business.....you couldn't make it up!! Their technical guy is going to get back to me with a solution hopefully, but changing the overhead switch might give the answer.
Having said that, if your 2023 car is doing the same thing, then I'm not holding out much hope of getting a resolution to be honest.
I still want to fit my Yuasa battery and change the SoC to 95% but must be patient with Ford CRC!! I can imagine the banging on about changing the battery and saying that invalidates my warranty!
Cheers, Steve.
  • 1 month later...
A quick update. I finally got the dealership to change the switch today after talking with their "master technician". We looked at the electrical schematic and you could see the input to the sunroof module from the BCM where the global opening signal comes from.
The only other inputs to the sunroof module are from the switch in the overhead console. This was enough to convince them to change the switch.
The switch appears to have cured the fault.
Cheers, Steve.
