sfrazer660 Posted September 9, 2011 Share Posted September 9, 2011 So my front windscreen washers aren't working and there is no usual whine of the motor trying to pump the fluid. I'm thinking the motor is done and needs replacing? From what I read of my Haynes manual it's inside the reservoir. Have I read it right? Has anyone replaced a washer motor? Quote Link to comment Share on other sites More sharing options...
stef123 Posted September 10, 2011 Share Posted September 10, 2011 So my front windscreen washers aren't working and there is no usual whine of the motor trying to pump the fluid. I'm thinking the motor is done and needs replacing? From what I read of my Haynes manual it's inside the reservoir. Have I read it right? Has anyone replaced a washer motor? before you go replacing it, have you checked the fuse is ok? if you can get hold of a multimeter you can also check if there is power getting to the pump.. Quote Link to comment Share on other sites More sharing options...
sfrazer660 Posted September 11, 2011 Author Share Posted September 11, 2011 Yea I check the fuse but heard the motor for a second today then it went offagain so it must be a loose wire somewhere Quote Link to comment Share on other sites More sharing options...
stef123 Posted September 12, 2011 Share Posted September 12, 2011 Yea I check the fuse but heard the motor for a second today then it went offagain so it must be a loose wire somewhere or possibly a bad earth connection.. Quote Link to comment Share on other sites More sharing options...
