Car Conundrums!
Which is powered by what?
A battery
  • Replies 3.3k
  • Views 183.2k
Alternator?
Battery is the answer. Technically you only need it to start the car, then you can unplug it and everything still works(1 fun fact that came from college)
You can, however, there is no reserve supply. If you draw too much current the voltage will drop too much and the engine may cut out.
You also run the risk of high voltage spikes and ripple on the 12V+ feed to everything - shouldn't really be an issue if everything is designed properly but can make electronics misbehave.
  • 2 months later...
A tyre
I think we should start this off again, as clearly someone forgot to return!
Without me, you will find someone else could drink me up!
  • 1 month later...
Fuel filler neck anti-syphon baffle device
Nicely done. Your go
Sent from my D6603 using Tapatalk
Ok, try this one...
I can weep on command, which pleases you
But should i weep without you: it will terrify you
what am I?
No, not screen washers
Aircon drain
No, not aircon drain
Brake bleeding nipples?
Correct,
Your go Sean
Correct,
Your go Sean
Crikey...I only wanted to get away with saying nipples :lol:
Hmm...okay...lemme think...
I am well trained to help you sit...what am I?
Seat position memory module
Good answer - but not the part I had in mind lol
An electronically controlled hydraulic valve solenoid from a VCT engine
  • 3 weeks later...
Well trained to help you sit...
if its not memory module, I go with lumbar support @SeanW
Close - but not quite there
I almost forgot what part I was thinking of lol
Seat Height Adjuster
Right area...
Seat Runners
Seat Runners
I'll give you that - I've always known them as seat rails
