Making Brake Line.
As far as I know, taking the strut out that way doesn't work as the hub bit won't go low enough.
Are the bolts seized in the sleeves of the arms?
Pretty much yes.
Just to let you know Stef, brake line is done. Flaring !Removed! steel line was a pain, but was able to do an inverted flare. Will find out next week if pressure is fine, so will let you know about that.
Just now need to figure a way to drop the struts on suspension, without breaking support arms.
