Knocking On Front
Drove to a friends house,about 1 hour,as soon as I started the return journey I developed a knocking on the front or so it seems,I can feel it through the steering
All new shockers and ball joints on the front
Any ideas please,just jacked it up on the front can't find anything
Dave
Possible drop links
Engine mount? Brake pad slipped from calliper? Bearing?
Sent via the 'Clacks'
GNU STP
Rocked the engine appears solid
Checked calipers
Rocked the wheels re bearings appear solid
New drop links both sides
CV joint?
GNU STP
Road speed or engine speed or only over bumps?
Stupid thought, but are all the wheel nuts tight? You'd be surprised how often that is dismissed due to it being a silly suggestion.
GNU STP
Hi yes had both wheels off,to look for any problems
Seems to be worse on bumpy roads
To check cv joint ,I will try running in a circle ,should be able to hear it cracking ,if it is the cv joint is it easier to change the whole shaft
Seing as you have had replacement shocks,.Have you checked spring sitting correctly and not broken.Shock top mount not loose the 1 where the shock gose through the top bearing.Anti roll bar bushes or subframe bushes
Good shout I reckon, I had similar symptoms on my Fiesta mk7, turned out to be top mount. Springs been done twice this year alone so it just wasn't put back properly.
Shocks ok
Will check anti roll tonight
