Head Light Washers Not Working
Hi everyone I have a mondeo St 220 tdci 55 in the year, I can't seem to get the head light washers to work.......... Any ideas ?
They usually only function occasionally as far as I know.
On my MK3 Focus ST they only activate every so often and then only when the lights are on so maybe a similar arrangement on your car?
Thanks stoney will give it a go and let you know.
had them on opel years back they only work when headlamps where on
Thanks theredfox
Yep, only functional with headlamps on
Still not working guys
check fuse 22 battery fusebox, and relay which is next to fusebox inside car behind glovebox
Can you hear the pump running? If so the pipes may be gummed up, hot water can solve this
I was told that they do not work every time the windscreen washers are used. I believe that it says that in the user manual.
Thanks all will let you know
